996 Forum 1999-2005
Bump steer correction front - setup advise
Old Mar 12, 2021 | 12:49 PM
BenGerman's Avatar
BenGerman
Default Bump steer correction front - setup advise
Since the bump steer on my C4S on the B8 / H&R setup is fairly annoying and I won't be changing to the GT3 setup just yet, I got my hands on a set of RSS bump steer tie rod ends.
Is there any general guideline on how the tie rod end should sit with the car on the ground? Are they fully level?
Before going into Trial & Error I'd like to put the rigth spacer in when installing them.
Thanks!
Ben
Old Mar 12, 2021 | 01:33 PM
SoCal911t's Avatar
SoCal911t
I don't have an answer but I'm curious if you're this BenGerman?
Old Mar 12, 2021 | 01:43 PM
BenGerman's Avatar
BenGerman
Depends who’s asking, but I have a feeling you own an E28?
Yes, that would be me!
Old Mar 12, 2021 | 06:16 PM
moburki's Avatar
moburki
Parallel to the lower control arm as best possible. You're trying to make the arcs replicate each other. Not one ahead or behind the other.
Old Mar 13, 2021 | 08:32 AM
BenGerman's Avatar
BenGerman
Perfect that helps a lot. Thank you!
Old Mar 13, 2021 | 04:16 PM
hardtailer's Avatar
hardtailer
Hhm that's approximate at best...
Outside front tire is supposed to toe-out under bump when cornering in order to negate lift-off oversteer.
When cars get lowered a lot this feature of the front suspension kinematics changes unfavourably (into bump steer) when you lower a car more, generally speaking, than what the factory offered as an option.
Lots of info in this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/888071-bump-steer-1.html but what it comes down to is that 'tie rod parallel to lower control arms' is not valid for each design of McPherson strut suspension but only for those where the steering rack is at the same height as the lower control arm, which it almost never is but in case of a 996 very close.
The real criterium is: the imaginary line along the tie rod has to intersect with the pole of the front suspension (in front view) at the new ride height.
This pole is also used to find the roll moment center.
Roll centre and instantaneous pole of motion on McPherson strut suspension
To achieve this after lowering you can either move the steering rack up or lower the position of the outer tie-rod end ball joint.
Establishing by how much is the elaborate part in this exercise.
Have you had the front and rear wheek alignment adjusted after fitting the H&R lowering springs?
Old Mar 23, 2021 | 01:54 PM
BenGerman's Avatar
BenGerman
Lots of info in this thread: http://forums.pelicanparts.com/porsc...p-steer-1.html but what it comes down to is that 'tie rod parallel to lower control arms' is not valid for each design of McPherson strut suspension but only for those where the steering rack is at the same height as the lower control arm, which it almost never is but in case of a 996 very close.
Yes, the car was aligned. I will get it redone after fitting the new tie rods, hopefully some time next week.
Thanks for detailed explanation. I was already aware of some of the details, such as the fact that I can't really compensate the roll center issue until I switch to the GT3 uprights in the fall.
That's where I was hoping the Tie Rods could provide a termporary solution. I will try the different heights that i can achieve with the RSS Rods and report back.
Old Jun 3, 2021 | 05:47 PM
hardtailer's Avatar
hardtailer
Any update on this?
A curious mind would like to know 🙂
Old Jun 6, 2021 | 06:16 PM
BenGerman's Avatar
BenGerman
Yes! I did the trial and error method for now, more to come next winter.
Tie rods are installed with one additional shim on top, lowering the tie rod end by 5mm. Afterwards I had an alignment done.
Don't have the sheet with me in europe but I believe -1.5° F, -1.8° R, 5' toe front, 35' toe rear, both total. Was hoping to get more camber, but we are maxed out with the stock setup.
Drove the car for about 1,500 miles on backroads and the bump steer is almsot gone. Car feels great, very pointy on turn in, maybe already a bit too nervous.
Next step is the GT3 setup: Coilovers, uniball mounts, wheel carriers, GT3 Control arms, RSR Uniball ends, cup rear tie rods. That should help
