Function First Shift-Right Solution Problem?
Hello, I recently installed the Function First Shift-Right Solution and my shifter still has a lot of play. Is this normal for this solution? Something just doesn't seem right.
https://youtu.be/rU_TbTfs8DY
That's probably play in the cable ends. It doesn't look like anything in the shifter assembly itself is flexing. My car has the Shift-Right with similar levels of play.
