996 Forum 1999-2005
285/35/18 on my C2?
Old 02-06-2021, 07:03 PM
pesuazo
pesuazo's Avatar
I have been running 275/35/18 in back and 235/40/18 in the front for years...love the ride
Old 05-05-2021, 06:00 PM
hoofdpijn
hoofdpijn's Avatar
Originally Posted by DSC800
Thanks for this. Not a lot of 285/30 choices is the only reason for me going to "35" but stock 225/40 availability is not a problem so I did look into keeping fronts stock since I don't have PSM. Based on responses and other reading that there is no rubbing, etc with taller tires I may go to 225/45 front and this will make front and back diameter 26". Still, I kinda prefer the shorter sidewall on the front for the handling.
What did you end up doing? I'm looking at the same dilemma in wanting to run PS4s but they're only available in 285/35 as near as I can tell. Less worried about rubbing than I am the traction control losing it's mind.
Old 05-05-2021, 06:08 PM
zbomb
zbomb's Avatar
Received 4,280 Likes on 1,807 Posts
On my C2 with PSM, no issues street or track with 285/35 and any weird TC/PSM intervention.
Plenty of vids in my sig of how it worked for me.
hoofdpijn (05-05-2021)
Old 05-05-2021, 08:31 PM
DSC800
DSC800's Avatar
I ended up sticking with 225/40/18 (8" rim) on the front and 275/35/18 (10" rim) for the rear. We mounted the 235's but they rubbed quite a bit. I think the Mk1's fender liner is more likely to rub than Mk2's, regardless, for my driving I'm not trying to get every cm of width so I just stuck with stock. Not going up to the 235 I dropped to the 275's in the rear and this matched the front/rear diameters to within 2/10s inch. Also, the speedo now reads only 1mph over at 70 whereas before with my 285/30's it was 4mph over. The ride is great but I replaced 13 year old Sumi's so anything would be an improvement.
For anyone else interested in the tires, they are the Michelin All Season 4S and, after 2k miles, so far so good. Of course you wouldn't want to get near the track with them but for the back roads and coastal cruising they are fine and should last. They came stock on the base Corvette so that's gotta be good, right?
Old 05-06-2021, 10:26 AM
hoofdpijn
hoofdpijn's Avatar
I ended up sticking with 225/40/18 (8" rim) on the front and 275/35/18 (10" rim) for the rear. We mounted the 235's but they rubbed quite a bit. I think the Mk1's fender liner is more likely to rub than Mk2's, regardless, for my driving I'm not trying to get every cm of width so I just stuck with stock. Not going up to the 235 I dropped to the 275's in the rear and this matched the front/rear diameters to within 2/10s inch. Also, the speedo now reads only 1mph over at 70 whereas before with my 285/30's it was 4mph under. The ride is great but I replaced 13 year old Sumi's so anything would be an improvement.
Awesome. Thanks for the info!
Old 05-06-2021, 10:32 AM
plpete84
plpete84's Avatar
Received 1,732 Likes on 885 Posts
Originally Posted by Dal
I just installed 235/40/18 and 285/35/18 Michelin Pilot Sport 4S on my 996.1 last week and haven't had any issues with rubbing. Currently on stock suspension so there's a good amount of gap, coilovers are going on soon but from what I'm reading I don't think 285's are going to cause an issue.
This is good to see. Looks like you're running Apex SM-10 wheels with an 11" rear rim? That's the size I'm considering in future for additional side wall. Any side shots?
Old 05-06-2021, 11:30 AM
yaz996
yaz996's Avatar
I've been running the same for a month now with Feal coilovers (at the max height) and 15mm spacers all around. Haven't noticed any rubbing.
Old 05-07-2021, 12:50 AM
cwbrown
cwbrown's Avatar
APEX Wheels
SM10
Front: 18x8.5” ET42 with MPSS 245/40-18 tires
Rear: 18x11” ET36 with MPSS 295/35-18 tires
OHLINS R&T
No spacers
No fender roll
No rub
No codes
The following 2 users liked this post by cwbrown:
Hazmat1071 (05-11-2021), plpete84 (05-07-2021)
Old 05-07-2021, 01:43 AM
jobyt
jobyt's Avatar
285/35 works fine on stock 18" wheels
Old 05-07-2021, 10:30 AM
plpete84
plpete84's Avatar
Originally Posted by cwbrown
APEX Wheel
SM10
OHLINS R&T
No spacers
No fender roll
No rub
No codes
I'm liking this fitment a lot! Thanks for sharing. Same wheels here just different offset in rear for narrow body but 295/35 looks perfect IMHO on there.
cwbrown (05-07-2021)
Old 05-07-2021, 03:40 PM
Hazmat1071
Hazmat1071's Avatar
Originally Posted by 996.2
We put on larger tires than stock at 235/40/18 front and 295/30/18 rear. Rear is slightly shorter than front and it doesn't look right, when they wear out we are planning on same size front and taller 285/35/18 rear. We also have a C2 with none of that electronic junk and will experiment to see if we can use spacers by temporarily placing different thickness washers behind wheels to check for rubbing issues.
Hi, I just ordered the same tire combo you just mentioned; can you tell me what you mean by the 'rear is slightly shorter?' I'll change the order if it's not going to look right.
fronts 235/40/18 18x8.5 53mm offset
rears 295/30/18 18x11 63mm offset
I have a 2001 C2 cab
Old 05-07-2021, 04:09 PM
Hazmat1071
Hazmat1071's Avatar
This setup looks great! will this a C2 Narrow body?
Old 05-07-2021, 07:55 PM
996.solo2
996.solo2's Avatar
295/30/18 will fit with enough negative camber...even with 11" 45ET wheels:
Even 315/30/18 tires will fit:
Up front, you can fit up to 275/35/18 tires, although I don't have a pic handy. Here, the car has 265/35/18 r-comps (which are about as wide or wider than non r-comp tires):
Old 05-11-2021, 11:14 AM
thurstonpowers3
thurstonpowers3's Avatar
Tell me more about this 275/35 front! I was always under the impression a 255/35 was about all you were getting under the front of a 996. Is that Fiske a 9" or 9.5"?
Old 05-12-2021, 04:08 PM
Tom2769
Tom2769's Avatar
Originally Posted by zbomb
285/35 worked great for me lowered on coilovers with spacers. Front to back on 2WD not a concern.
Z, do you know what color your old wheels were painted? This is the perfect "bronze-y" color IMO...
Quick Reply: 285/35/18 on my C2?
