P/n for MT shift rod seal?
Hi,
I need to replace my shift rod seal in my '99 C4. I know I need to pull and split the tranny, but I think that's doable. I'm struggling to find the part, though. Any leads?
Frustratingly, the seal started to leak within 5k of the transmission rebuild 30k miles ago. The previous owner has records saying it could be replaced under warranty, and he never did it.
Anything else easy I should do while I've got the tranny down and split? If it looks bad, I suppose it'll be a trip down the road to GBOX. But given the recent rebuild and the fact that it shift o.k., I'm hopeful. I'm going to do the clutch and RMS if it needs it. Hoping the flywheel is o.k., but not super optimistic (its about 50k old, but on its second SPEC clutch disc, per the records). IMS bearing was done with the LN kit.
Thanks,
Paul
Thanks,
Paul
Paul Janda (02-02-2021)
