Cutting WB Lobsters to fit NB C2 Cab
diddy2003 (12-17-2020)
Not to hijack the thread, but it will be getting some nice additions over the winter. Winter projects. .5 quart LN deep sump oil pan, UAOS, water pump/chains/guides, phenix engineering toe links to replace frozen originals, lower control arms with solid bushings, new transmission bushing and RSS engine mounts, and a center radiator with LN low temp thermostat. Thanks a lot to my friend theDeckman that owns Phenix Engineering.
...but if you're friends with the Phenix Engineering owner, I suggest installing his aluminum shifter bushings.
https://phenixengineering.com/shop/p...ft-bushing-kit
Cheap/quick/good mod to do.
Sounds like some good upgrades.
