996 Forum 1999-2005
thermostat bolts replace?
Old Oct 5, 2020 | 05:45 PM
danix's Avatar
danix
Default thermostat bolts replace?
If I had them, I would totally replacement given the low cost. My question is - do I have to?
I believe based on color, the bolts are one time use/stretch bolts. But my dealer doesn't stock them, doesn't know how long to order them, and I'd like to get the car done sooner rather than later.
So if I can reuse them, I probably will because it's that or wait.
Old Oct 5, 2020 | 06:39 PM
theprf's Avatar
theprf
The greenish tint on the bolts is anti-corrosion passivation. I don't believe they are a torque to yield bolt, that would be strictly foolish for this application, you'd tear the threads out of the aluminum housing long before the bolt even thought about yeilding. They are probably listed as one time use because the anti-corrosion passivation may be compromised leading to dis-similar metal corrosion between the bolt and the housing.
I would reuse and add anti-seize paste of some sort. I like the Permatex Nickel based product.
The part# is listed as 900.378.030.09 and they show as $0.45 each at Gaudin Porsche Parts if you are inclined to go that route.
Old Oct 5, 2020 | 06:49 PM
danix's Avatar
danix
900.378.030.01 is what I have I think (M6 x 20mm). Point taken on the coating, thanks!
Old Oct 5, 2020 | 08:47 PM
theprf's Avatar
theprf
I had a typo, it's listed as 900.378.030.09 in my 10-year old parts catalog and I agree it's M6x20. That .09 is superceded to the .01 number.
Old Oct 5, 2020 | 09:11 PM
Quadcammer's Avatar
Quadcammer
Nah, id not bother replacing them
Old Oct 5, 2020 | 09:59 PM
danix's Avatar
danix
Thanks everyone!
Old Oct 5, 2020 | 11:12 PM
TexSquirrel's Avatar
TexSquirrel
I replaced mine, but then have used them on a spare engine.
They all torqued just fine.
Old Oct 7, 2020 | 12:27 PM
808Bill's Avatar
808Bill
Just make sure not to over-torque them!
Old Oct 7, 2020 | 01:07 PM
TexSquirrel
Yes! A broken bolt here would suck.
You'd probably have to drop the engine to repair it.
