996 Forum 1999-2005
Sport Design Wheels: restore or replace
Old Jul 11, 2020 | 03:16 AM
Otto Bonn's Avatar
Otto Bonn
Default Sport Design Wheels: restore or replace
Cheaper to just replace than re-finish this wheel? The other 3 are ok.
Old Jul 11, 2020 | 03:41 AM
lowpue's Avatar
lowpue
Why not refinish? Less than another wheel, no?
Old Jul 11, 2020 | 07:08 AM
dporto's Avatar
dporto
Seriously? Uh... NO! It'll probably only cost you $200 or so to refinish - the only potential problem being that the refinished wheel looks better (or slightly different) than the other three...Just DO IT !
Old Jul 11, 2020 | 07:43 AM
SKM's Avatar
SKM
Default Refinishing
Refinishing is probably the better choice since you know the wheel does not leak air, is straight and true and it coat less. May have to refinish the other wheel on that side of the car to get the color to match. Try to avoid disassembling the wheel as it may leak after assembly. Be sure the correct Porsche silver metallic is used, which may be 61M.
Old Jul 11, 2020 | 09:25 AM
rockhouse66's Avatar
rockhouse66
I had mine refinished and insisted they be disassembled to be done properly (not masked and painted). They can't leak. They aren't 3 piece wheels. They are 2 piece and the bolts just hold the face of the wheel to the one piece rim.
BTW, the first place I took them refused to disassemble due to leakage liability. They made the same mistake - because they do appear to be made like a 3 piece wheel.
Old Jul 11, 2020 | 10:38 AM
dporto's Avatar
dporto
^^^ To be done properly, they need to be disassembled - If the shop doesn't know that, take it to another shop - any shop worth it's salt knows how to deal with these BBS wheels (and has probably done many, many others)...
Old Jul 11, 2020 | 12:27 PM
Otto Bonn's Avatar
Otto Bonn
yes, it is a two piece rim and leaks are not a problem. These are not the most desirable rims but I'd like to stick with them. The clear coat is starting to fail.
Old Jul 11, 2020 | 04:40 PM
Cockyjohn's Avatar
Cockyjohn
I am getting all four of the exact same wheels refinished next week (a bit of corrosion on the polished lips and mirror face damage). Can anyone confirm that the paint colour forifor these rims is Silver Metallic 61M? I sent pictures to the refinisher and he thought they might be hypersilver but he wasn't sure. I bet as soon as he sees them in person he will know the exact colour but it would be good to have beforehand. Thanks in advance.
Old Jul 11, 2020 | 04:52 PM
lowpue's Avatar
lowpue
I think we are saying the same thing....
Old Jul 11, 2020 | 05:03 PM
Cockyjohn's Avatar
Cockyjohn
Or should I change up the colour? Gun metal grey? My car is this car's twin - same colour and with aerokit.
Old Jul 11, 2020 | 06:38 PM
Otto Bonn's Avatar
Otto Bonn
Haha. Yes, you would think. When they are refinished do they reproduce the machined appearance on the lip?
dwhitlow's Avatar
dwhitlow
I'll just drop this here... :-)
Old Jul 11, 2020 | 07:53 PM
Cockyjohn's Avatar
Cockyjohn
Yes they should machine the lip when they refinish the wheels.
Old Jul 11, 2020 | 11:41 PM
Slopeslider's Avatar
Slopeslider
Go for the gun metal gray. It really modernizes them.
Old Jul 12, 2020 | 02:00 AM
Otto Bonn's Avatar
Otto Bonn
the lips are different. the machine lines are inconsistent. are they able to replicate this?
