Brake disc change
Originally posted by Gretch
Jim, you beat me to it. There is a lot of misinformation posted in this thread. The article Jim linked to above is a good read for all the guys who "think" they know what they are talking about. You know who you are.
Both recommended changing the pads when renewing the discs. The issue with worn pads seems to be that the worn pad will only make contact with the disc in a few sports. This obviously results initially in reduced braking performance, but the real issue is that these spots get very hot, which can change the material structure in both the pad and the disc.
If you absolutely must keep your old pads, ATE recommended to be gentle with your braking for the first 500mls or so, until the worn pads make full contact with the new disc. This seems to contradict what was said in above article. Also, according to ATE, deposit of brake pad material on the disc is not much of an issue with modern compounds.
NB: All this information is concerning road use. Track use might be a completely different story.
Cheers,
Uwe
