Cab Cover Trim
I’m looking for a thread or tips on how to repair the piece shown on my 99 cabriolet. The car spent it’s life in Southern California and the trim piece is disintegrating. I’m not even sure what the material used under the cloth cover is, almost feels like hard foam. My car isn’t valuable so I’m looking to repair it as simply and reasonably as possible. I have had a tough time even figuring out what the part is called. Any help is appreciated.
Not on a porsche ,, but I have carefully removed a rear deck cover and covered it with fiberglass to retain the shape then glued a good grade of felt to it, easy to fit and stretches over teh curves,, attached with 3M upholstery adhesive..
I've had that out to upgrade my stealth-installed V1. It's not hard to remove. Remove the wall behind the back seats and remove two or three screws holding it in. Put the top into service position and pull down the carpeted wall on the other side ( I think there are some plastic clips). Remove the four or five screws from that side. It lifts up as one piece. It's plastic.
