Cab headliner sag
Cab headliner sag
I searched but couldn't seem to find anything on this particular issue. My headliner sags at the rear where the last hoop goes across. At first it appeared the hoop was not being pulled rearward enough, but when I look at pictures of other cars from the outside, it appears mine is in the correct position.
There are also flat plastic bits at both sides, above the rear quarter window. They "look" like they should slide into something, however seem to just hang free and there is nothing for them to slide under or attach to?
Anybody replaced a headliner or had similar experience?
That sag is pretty bad looking. I have the issue like you due with the headliner in the rear corner that I have to address by putting the top in service mode position and figure out why it’s not fitting correctly. A recent thread I started about my headliner has a link that may help you on the installation of the headliner.
That sag is pretty bad looking. I have the issue like you do with the headliner in the rear corner that I have to address by putting the top in service mode position and figure out why it’s not fitting correctly. A recent thread I started about my headliner has a link that may help you on the installation of the headliner.
ssgunny (02-15-2020)
Got it sorted! Turns out there is a fabric strap that links the structural loops together front to back. The rivets tore out of the strap on one side. Drilled out old rivets and replaced with a couple of button head bolts. Much improved.
Before
After
Before
After
I got rid of my headliner a couple of years ago...was gonna buy a new one, but decided just to live without it....the price of a headliner is almost the same as the price of an actual convertible top...just ridiculous....
Can you tell me what differences you encountered with the headliner out...noisier, etc>? TIA
