996 Forum 1999-2005
Coolant Temp Sensor Issues
Old Jan 13, 2020 | 08:15 PM
jdarland02's Avatar
jdarland02
4th Gear
Default Coolant Temp Sensor Issues
On my way up the driveway last night after a drive I managed to stall the car and upon restarting it I had a code pop up on my dash signaling a temp failure indicator along with my water temp gauge bottoming out and the little amber warning light next to it start blinking. I shut the car off and restarted it only to get the same set of warnings on the dash. This is the first time this has ever happened and when I posted it in a 996 facebook group and I was told that my coolant temp sensor could be out, but after searching a bit it seems that this could also be a low voltage/post stall issue and it could fix itself. Has anybody else had this issue?
Old Jan 13, 2020 | 11:59 PM
az968gpw's Avatar
az968gpw
My car has a similar but different issue. When driving when outside air temp is low this same warning condition occurs just as the temp gauge starts to move off full cold. After a few mimutes it clears itself. Replaced the temp sensor, cleaned all grounds, cleaned all connections relating to the sensor and resevour. Going on for over a year. Still occurs. Hope you find a cause.
Old Jan 14, 2020 | 09:59 AM
808Bill's Avatar
808Bill
Low on coolant? Going uphill with low coolant and the sensor is at the forward point of the tank. Maybe you just need a top off of coolant?
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
