larger rear tire advise
Hello guys.
i recently installed Ohlins R&T coilovers on my 02 C2, and lowered the car.
now i would like to add some wheel spacers, to get them as as aligned with the fenders as possible.
the front is looking good, so i just need spacers there. the rear fender is looking a bit "empty" so i was wondering if there is a way to "fill it up" with a larger tire (before taking measurements for the spacer, or maybe i will not need a spacer at all)
at the moment i'm running on Bridgestone Potenza S-04 285/30 R18 on the OEM lightweight wheels, which are 10" wide i believe.
any advice will be greatly appreciated..
We have 295/30/18s no rubbing and wheel well still looks empty. Stock suspension, 65 mm back spacing. Planning on trying 285/35/18 next, other posts said no rubbing even lowered and with spacer.
Always hesitate to circumvent Porsche enginnering for which we pay so dearly.
Elumere (01-11-2020)
jokes aside, aren't most of the track cars are using different tires and wheels than stock?
i believe that some of engineering decision has to do with cost fuel consumption, and emission regulations.
The following 3 users liked this post by meirschwartz:
your car looks great. the 315's will probably won't fit the OEM wheel.
Ratchet1025 (01-09-2020)
315/30 wants to be on 10.5 to 11.5 wide rim. Those 5 spoke wheels are 10 inch so a little bit narrower but could still give it a shot. Might not be ideal for Max performance but you are not likely to be competing on those wheels and tire combos anyway.
Will get more pics when they let me out of the dungeon.
Ohhh, weight down to 2950, please share the details, this is my goal as well...
