996 w/997.1 transplant; can't pass smog...
I'm not an engine builder and so maybe someone here that has taken Jake Raby's engine class can chime in, but while it may seem they're very close in design, inside on these engines is another story. For example, Porsche increased the displacement to 3.8L for the Carreras. That meant a larger bore and stroke which translated to higher HP numbers. While the two engines used similar "VarioCam+" systems, timing on the newer M97 was modified to support the increased HP and torque requirements. Seems to me the engine management software was working overtime to keep this engine running. I'm surprised you didn't get more codes.
Another option would be to run a custom tune. Put the car on a dyno and tune to the correct AFR. Even lean it out a little to get you through smog. I came from the world of custom tuned ECUs for Japanese cars years ago. I'm honestly not sure what's available in the Porsche world, but if this is an option it would be a heck of a lot easier than pulling the engine again.
Captain Obvious
Super User
Super User
California does not require tail pipe testing for 2000 or later models anymore. All they do is plug in an OBD2 scanner and if everything is good, you pass.
@NuttyProfessor my 07 motor is a 3.6l and is pretty identical to the 02 at least on the outside. Ancillary parts are all identical. I don’t believe the 997.1 motor is all that different mechanically to the 02 996 motor. A ton of the parts on the 997 have 996 part numbers...
@z driver 88t @Imo000 @yelcab Yes, CA is simply a plug in now, no sniffing... they do a visual of the engine bay to make sure nothing looks amiss, check the dash to make sure the CEL is not on and that’s pretty much it. Pass or don’t pass... While in this particular case it’s a pain, I do think our relatively clean air is worth having ...
We've already determined your M97 has a different SAI pump, right? And, we already determined the fuel injectors are different, right?
Are the scavenge pumps different? Does one of them have a brake booster on them? The M96 doesn't have that.
Thanks for clarifying what M97 engine you're implanting. I still think there are some notable mechanical differences between the two engines even though they share a lot of the same parts and have the same displacement. There wasn't a tremendous amount of power jump between the M96 3.6L and the M97 3.6L, but enough of a difference in engine management to cause the issues that you're experiencing. Seems like you got some good advice here on the forum. Hope you find a solution.
@NuttyProfessor I don't believe the oil pumps are different between the two motors but to be honest, I didn't really look hard at them. I will tho...
Yes, got some great info here and have done throughout my swap process so thank y'all for that...
I'll try to get in and under the car tomorrow and look for those differences you mention...
In my opinion, you are just shooting in the dark unless you use a code reader to pull the specific codes and systematically troubleshoot them. Everything else here is just a guess. A CEL could even be for some unrelated reason, but you won't know until you pull the codes.
I think yelcab is exactly right and where similar issues we ran into and had to correct. I vaguely remember we had to do something with fuel injectors as well and that maybe even the ECU had to be swapped but I may be remembering wrong which is why I would call Dundon...he has been there and done that successfully.
lowpue, in my opinion, you are in a slightly different boat going from the 996.1 to the 997.1. There is a lot more work involved in that swap, as I understand it. The 996.2 and 997.1 are much closer from a wiring, engine management, and fuel system perspective. No doubt Dundon can help, but are they likely to share this information with someone who isn't a paying customer?
cds72911 (01-05-2020)
