1999 911 purchase
1999 911 purchase
Hi all. Hoping to become owner of 1999 996. This one has some residue at the bottom of engine. Rubbed off on my finger, but no drips on floor or ground. IMS done 30k ago, but no records of RMS. Driving it, the ride felt good, nice and tight, but clutch felt pretty tight, to me at least. I started it 3 different times and every time it was a slow turnover before it fired up. Owner said battery is new. Owner agreed to vehicle inspection, but I wanted to get some opinions.
Honestly it is really going to depend on the inspection you are getting. Seems like the RMS should have been done with the IMS unless it went bad. The air oil separator is another issue that happens with these cars and can cause a leak although I am not sure if it would leak to the location in this picture or not. Someone correct me if I am wrong but the AOS is on the driver side rear of the engine.
AOS are pretty notorious for being unreliable, if it was done in the past few years it could very luckily have gone again. That being said the inspection will turn up what it is.
That seems like a lot of goop on the engine. I would make sure the PPI dude concentrates a reasonable amount of time determining where that is coming from. One would think that if it was there prior to the last work done the mech. would have cleaned that off...
Any particular reason you are set on this 996? If you like 99s check this out.
https://bringatrailer.com/listing/1999-porsche-911-36/
85eurocarrera (11-10-2019)
First time I've heard the Taco called a "folded magazine"... Geeezzzzz, what's the guy a librarian or something? I'd be wary of the new sump plate... What happened to the original one? Any surrounding damage to the sump? Welds? Certainly not a total dis-qualifier, but I'd have to hear the story ( "I took the motor apart and... lost the sump plate" ..."my dog ate it"..."someone stole it"... It's a nice looking car otherwise - I wonder what it will sell for?
Overall, you can get a good sense of how the car was taking care of just by looking at the appearance inside and out, and of course, if they had good service records on the car. The best advice is to not skimp on the Pre Purchase Inspection. Even if it passes with flying colors, be prepared to dump $5,000 in preventive maintenance. Good luck!
Metty (01-07-2020)
