Cabrio Roll Bar Cover Replacement
Hopefully someone can help with this problem. Replaced my roll bar cover tonight - the old one was literally crumbling and one of the little oval covers had blown off while driving down the road. Got a new (used) one from DC Auto - it looks beautiful and like new. Here is the problem - my old one mounted with three screws - one under the material in the top well, right in the middle of the car, and two in the front - behind the carpet in the back seat area - right next to the seat belts. But - my new one does not have the plastic molding where the two front screws go - just the one in the rear. I cannot see anywhere else that it is set up to attach. Exact same part number, but clearly a revised part. Has anyone else run into this issue?
Thanks in advance!
Daryll
Thanks in advance!
Daryll
Roll Bar Attachments
Mine is a 997 but I can't imagine it is much different. I had mine off this weekend. The rear mounting screw is in the middle of the back side, and there was one on each side under the pop-up roll bar covers themselves on the outside that screwed into an "L" bracket. Do you still have the old one for comparison?
Thank you very much!
Daryll
Check out these instructions and see if this helps clear things up:
https://www.diyauto.com/manufacturer...a-997-by-wiggy
Daryll
Yep, I agree with you that there could have been an update during the production run. If you don't have the L brackets you could probably source them from Pelican or another supplier, or even fab them yourself. Mine are held in place by the upper front side bold on the aluminum column It will be apparent when you look at where the screw holes for the cover line up.
Good luck!
Good luck!
Good luck!
Good luck!
Daryll
Update - talked to Rex at dC Auto - they are sending me the L brackets from a newer 996 cabrio. So - hopefully problem solved. Hopefully I don’t have to drill in a tight spot to install. Clearly there was a running change but why makes no sense to me. The way the old ones are secured seems far better and simpler than the newer cars.
Daryll
Daryll
