996 Forum 1999-2005
Extending pick up tubes
Old Aug 5, 2019 | 07:47 AM
Sveach756's Avatar
Sveach756
Default Extending pick up tubes
My 3.4L has the LN 0.5 quart spacer with x51 baffles and 997 pickup tubes. If I put a larger capacity spacer in will I need to adjust the pick up tube length? In theory this would be an easy swap but I'm not trying to risk an engine on a theory.
Shawn
Old Aug 5, 2019 | 04:38 PM
cds72911's Avatar
cds72911
The two quart LN sump kit I have has a (deeper) pickup extension.
Old Aug 6, 2019 | 02:10 AM
pdxmotorhead's Avatar
pdxmotorhead
The pickup comes with the spacer doesn't it??
Old Aug 6, 2019 | 03:11 AM
Sveach756's Avatar
Sveach756
I found a great thread outlining the mantis sump extension, which doesn't come with any longer pickups. However the LN 0.5 quart extension currently on my car does have the extensions. Problem solved.
Shawn
Old Aug 6, 2019 | 08:03 PM
cds72911's Avatar
cds72911
LN engineering 2 quart sump spacer:
Old Aug 15, 2019 | 03:12 PM
DeanClevername's Avatar
DeanClevername
Shawn
You're propagating incorrect information. Mantis' website clearly states and shows that their deep sump kit #1 it comes with a pickup extending spacer, kit # 2 stated it also comes with one (despite not showing it in the pic). I installed the Mantis sump a few years ago and can confirm that mine included a pickup spacer. I'm not affiliated with them in any way.
Source: http://www.mantissport.ca/ProductPor...4/Default.aspx
Old Aug 15, 2019 | 04:00 PM
Sveach756's Avatar
Sveach756
I appreciate the information and clarification. I bought my boxster with the 3.4L swap and a 0.5 LN sump spacer installed, so I wasn't sure what I needed.
I did end up buying the mantis 1.5L sump spacer and it does come with the space for the pick up tube. I was misunderstanding the pickup tube design.
This thread helped my visualize what I was getting into and needed.
https://www.planet-9.com/reviews/cay...extension.html
Shawn
File Type: jpg
Old Aug 15, 2019 | 04:27 PM
DeanClevername
All good! I just know how it feels to be a business on the wrong side of incorrect info that keeps propagating online haha
