P0491 - Seek advice
'02 C2, 176,000 miles, original engine. Owned 7 years.
About 2 years ago my car started throwing code 0491 (secondary air injection system, IIRC). Had my P car Indy look at it when I had it in for something else. He thought it was the pump, but since the car ran fine and we have no DMV pollution checks to worry about, he thought it would be fine to just let it go for the time being.
It would throw the code occasionally, although under all kinds of circumstances, so I couldn't draw any conclusions. Lately it's happening more often. Car runs flawlessly. Do I need to address this?
Won't hurt car other than maybe foul cats is what I heard since fuel will be too rich. Air injection pump just makes sure there is more oxygen in the exhaust so that unburned fuel will burn in the cats....at least that what I have been told.
Bill, the air injection does not effect the engine....in the first 30sec when the air pump turns on and the engine is cold, engine tends to run rich whether pump is on or not. The injection happens in the exhaust system and not the engine so there is no impact to engine combustion whether the injection works or not. This is purely an emissions thing to burn off gasoline vapors in the cats.
Southern man, the vacuum lines are needed to open up valves to exhaust system so air can be pumped in. Once engine is warm pump turns off and valve closes so exhaust won't backflow into pump and foul it.
Same thing happened on my Mercedes....replaced crack vacuum hose in that case.
Report back on what eventually solves your CEL
Now help me understand this, if the SAI vacuum leak gives a false reading, then adding more fuel, does it not wash down the cylinder?
Think of it this way....the combustion has already happened...the exhaust leaves the engine with still some unburnt fuel vapors mixed in....it goes to the catalytic converter which are not hot enough so all the vapors don't burn yet because there isn't enough oxygen....so they inject oxygen before the cats so it could burn more fuel and get cats hotter faster so they are full function sooner and lower emissions. Air injection pump is all about cat efficiency and has nothing to do with engine other land the oxysensors detect the problem and CEL. I am no expert but I am pretty sure I have this right....so stop worrying about fuel wash
I appreciate the quick 101.
Good article i found as i got the code last week. I cleared it and it hasnt come back yet.
http://p-car.com/996/diy/sai/mainpage.html
