996 Forum 1999-2005
Coating for "polished" headlight
Old 07-24-2019 | 03:12 PM
dak911's Avatar
dak911
Default Coating for "polished" headlight
I've been able to get my headlights looking clear with rubbing compound, now I need a clear coating.
What works and won't yellow?
Old 07-24-2019 | 03:21 PM
808Bill's Avatar
808Bill
I'd go with the clear vinyl laminate for added protection.
Old 07-24-2019 | 05:11 PM
moburki's Avatar
moburki
Porsche Boxster (97-04) Headlight Covers
Link I have saved for GF's car. Change the model for 911.
Old 07-24-2019 | 05:32 PM
dak911's Avatar
dak911
I'm wondering if there is a spray can of some kind of coating?
Old 07-24-2019 | 05:38 PM
WrngCLD's Avatar
WrngCLD
I would use a good wax/sealant and give the headlights a good coat.
dwhitlow's Avatar
dwhitlow
I've gone with a spray clear coat after polishing my lights in the past, and they still wound up yellowing pretty quickly after that. I may not have used the right spray in the first place, but it was disappointing.
I wound up getting the Xpel brand pre-cut headlight films and putting those on after re-polishing. That has held up really well and the lights still look clear and sharp even after a year of driving, sitting in the sun, etc. I think I purchased mine from Amazon.
Old 07-24-2019 | 05:41 PM
Optionman1's Avatar
Optionman1
when i had xpel installed on front half i was told they don't cover the headlights due to the heat generated. that's the extent of my knowledge on the subject. good luck
Old 07-24-2019 | 10:01 PM
808Bill's Avatar
808Bill
They must not have known any better because they specifically make pre-cut kits for them now.
Old 07-24-2019 | 10:12 PM
dak911's Avatar
dak911
ClEAR COAT spray......anyone?
Old 07-24-2019 | 10:24 PM
motoo344's Avatar
motoo344
Spray them with actual clear coat? I usually put a ceramic coat on them but you certainly spray them with actual clear coat.
Old 07-25-2019 | 03:33 AM
latonnelier's Avatar
latonnelier
I took mine to a body shop and they sprayed them with their clearcoat ( I had to rough the polish with 2500 grit paper) for a case of beer. They just did them along with a car they were finishing. OK, I know the body guys
Oh, and then I put Xpel on the lenses
You could also get a can of 2K clear -- its a 2 part (puncture to activate thing) and spray the lights.
https://www.walmart.com/ip/U-S-Chemi...SABEgJEzPD_BwE
Old 07-25-2019 | 07:16 PM
joseph mitro's Avatar
joseph mitro
http://986forum.com/forums/boxster-g...oat-wipes.html
guys in this thread talked about clear coating their headlights. I still can't understand the logic. the lenses are permanently altered and if done incorrectly the lights are forever ruined.
apply lamin-x or xpel and be done with it.
Old 07-25-2019 | 07:40 PM
Bob Dobolina's Avatar
Bob Dobolina
I put on Jetseal by Chemical Guys.
Old 07-26-2019 | 01:50 PM
dporto's Avatar
dporto
I went with the Expel pre-cut laminates for mine. It's been over a year (maybe 2???) and they're still clear...
Old 07-26-2019 | 01:57 PM
808Bill's Avatar
808Bill
Does it lay flat out of the box or do you need a heat gun?
Quick Reply: Coating for "polished" headlight
