Hope it's not bore score
Since last oil change (2000 miles), no oil consumption, never seen any really.
Tick seems to be constant and goes with the speed of engine.
Never see smoke, but then again, cant see that from in the car.
Tailpipes look as they have they entire time I've had it, never overly dirty.
Will have to look at changing oil and see what it looks like currently. I dont recall what if it was dark or not last time. But that was also before the tick.
I havent noticed any other symptoms. Just the sound, maybe its just all the talk here recently that has me thinking beyond the norm.
Just a car guy
Seeing a more detailed explanation would also be helpful, for me.
Just a car guy
Good points. Removing the belt for a short trial might not be a bad option. If the sound persists it will likely be an internal issue. The stethoscope should be helpful, before messing with the belt.
Just a car guy
It's there and he does state that it's tricky getting up into (5 or 6) one of the two if I recall. Also, the plugs will tell you a lot.
https://www.youtube.com/watch?v=TH8oMLMkkrk
My plugs looked good when I had them out 2000 miles ago. The bores seemed OK, as well, as seen from the top of the pistons. I'm not losing sleep over this, but I would feel better if I had seen more of the bottom of the bores...
Just a car guy
Hard to tell from that - unsighted - sound bite.
You (OP - sorry Strath.. ) have, or were going to get a stethoscope, correct? Let the car idle and try to get a good listen to each injector, as best you can (understanding space is limited). Do the best (subjective) comparison you can from one to the next. Also - verify first, that the noise you were concerned about truly is injector sound (i.e. don't trust everything you read on the internet).
Finally, if you have, or can gain access to the Durametric tool, you can look at data to help you determine if there might be an injector (or other possible) concern.
I'd have to go back and check my thread. There are individual cylinder 'balance' parameters that you can monitor with the Durametric. Balance in quotes because it may be under a different name (efficiency, for example). This is a more advanced step to take. Try the stethoscope check first. Personally, I think there is nothing wrong. (Again, see above - about trust).
You have, or were going to get a stethoscope, correct? Let the car idle and try to get a good listen to each injector, as best you can (understanding space is limited). Do the best (subjective) comparison you can from one to the next. Also - verify first, that the noise you were concerned about truly is injector sound (i.e. don't trust everything you read on the internet).
I will look at injectors and see if any sound different.
The video portion was useless, just the rear quarter panel shown.
As far as a durametric, without going to an Indy or dealer, no access. Are there other readings that can be pulled from the OBD2 port that would show a potential issue?
There is definitely a tick that was never heard before this weekend.
Just a car guy
I got the stethoscope, but not time to look at the car yet.
Relax. You should be able to tell if one injector sounds different from others. Or otherwise locate the source of the new sound.
And no. There are no parameters of any value from the OBD port without a proper tool. If you don't have a check engine light, there will be no engine (emissions) related codes to collect.
And this was right after seeing the latest F6I video on bore scoring, right?
Wasnt sure if anything that say OBD Fusion is capable of showing would give any indications. There are many things you can monitor, but I wouldnt really know what specifically to look at or what ranges.
Just a car guy
Ha, the only one I watched was part 4 and it was after I started hearing it. I'll see what I can find out.
