Fuel ADDITIVE
I have used both seafoam and techron and find the techron works better.
I think it's not a bad idea to rotate fuel additives. I usually use Techron, but I found that Seafoam seemed to work better when I tried it. I suspect if I used seafoam regularly, I might see a bigger difference when using Techron because they all probably work a little differently and are better or worse at various types of deposits. I've used Joe Gibbs stuff also, though I don't remember the impact of that specifically. I plan to rotate going forward.
Flame suit on - there is also Marvel Mystery Oil - that stuff is magic in vintage cars. I've used it in our Audi a couple of times - seemed to work well. Not sure I'd broadly recommend it for modern cars though (although there are a ton of people who do use it every tankful on modern cars and claim it improves gas mileage).
Yup, here in California I am limited to 91.
IIRC I thought it was Techron that was approved.
