engineering: thrust load on IMSB
I'm trying to decide between the LNE Retrofit (ceramic ball bearings) and the RND roller bearing for my IMSB replacement.
I've done some reading about both...my main question is: why would there be much axial (thrust) load in this application?
Thanks.
Thanks.
Ball bearing seems to be a more appropriate application from what I've read. But, the SOLUTION trumps all.
An I am surprised why you can't use google and the Rennlist search function. IMS bearing == rehashed over and over and over.
But hey it's your car - install whatever you'd like.
From this non-engineer's perspective, radial load capacity is really all that should matter.
If so, the intermediate shaft is like an airplane's propeller, when the engine engages and shaft is under load, there is axial thrust. That thrust on the shaft could damage a cylindrical type bearing.
I hope I am remembering this correctly. The other end of the IMS has a plain bearing with no thrust control at all. So all of the thrust load is handled by the IMSB at "this" end of the IMS. I can't say I know where the load comes from, it is probably not a large load, but it exists. Probably any spinning shafts has some thrust load, even if it isn't for some explicit purpose. So it is important for the IMSB bearing to handle it. It is getting hard to find the reference (source) for this point, but it is here somewhere on the forum.
Beyond taking a class in mechanical engineering, one of the quickest sources of information is by going to YouTube and searching "axial load engines". There are many videos that describe and demonstrate axial load/thrust.
Centrifugal force of the IMS combined with the gravity pull from the moon and the earths rotation = axial load..
.I don't know **** on this topic!
I'll try to set aside some time to cruise youtube...
