True, that's just what I went with as the torx 40 was a bit too small and the torx 45 was a bit to big.
I guess I will be buying a triple square set of sockets
If your going to be the DIY guy, these cars need some unique tools, and it pays to have them.
Amazon is great at getting them quick when you can't find them locally.
The threads have blue locktite from the factory, so they will be difficult to break loose. If you plan on replacing the door lock assembly, you can just drill out the heads off the screws since they thread only into the door lock assembly. Replacement mechanism does not come with new screws, just fyi.
I've come to realize this. It's not the first time I've had to purchase new tools from there. Of course I'm not patient and would prefer going to the local Home Depot and getting them if I can.
The set I posted is from VIM tools; they are the private label manufacturer for brands like Mac Tools, Snap On/Blue Point, and Matco. You're saving a good chunk of change buying it directly from them rather than off the tool truck. You can find more tool truck brands here.
