RENNKIT™ Carrera 4S Cal*Cool™ Brake Cooling Kit
Basic Sponsor
Carrera 4S owners might be interested in upgrading to larger 350mm brake rotors up front - if doing the upgrade we offer a new Cal*Cool™ kit that includes longer bolts and a novel cooling plate that reduces front caliper temps during spirited or road track driving.
You can learn more HERE.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
I'm a little confused. Your website states "Cal*Cool™ caliper coolers simply bolt on between rotor and wheel hub assembly". Shouldn't that state they bolt between the caliper and upright/knuckle? Don't the just become a spacer to move the caliper out further for the larger rotor diameter?
Basic Sponsor
Ok....but still you are not spacing the rotor from it. Your spacing the caliper. If you put it between the "hub" and "rotor" you would shoving the rotor out no different than a wheel spacer.
Technically Mbren is correct - the Rennline description should be..."between the wheel carrier/hub assembly and the Caliper" (not rotor)... What does being "fun at parties" have to do with a poor technical description of a (pricey)product?
Man, tough crowd LOL! I stand corrected. Couple of you are right. Our description had a typo, now corrected (thanks Mbren and dporto), references a cooling assist device inserted between caliper and wheel (hub) carrier using longer (and stronger) bolts. The picture in the first post shows it. Yes dporto there are cheaper alternatives out there, but they do not have any effect on cooling assist to the caliper. I'll discount the kit at 25% off for the first 5 to buy and try. 2 year limited warranty.
Captain Obvious
Super User
Super User
I don't know how this creates a cooler caliper. Most of the heat on track is transferred from the rotor, through the pad material, to the pistons in the caliper, fluid and so on.
It would maybe enable using larger rotors as the swept area is more outboard and maaayyyyybe more brake torque.
What about wheel barrel and spoke design clearance?
This seems like a solution looking for a problem.
When the caliper gets hot from braking, the heat will not magically radiate down to the mounting point of the caliper to these little gizmos. If anything, this will keep the hub from getting hot, but that's what brake ducts are for.
Basic Sponsor
