Tool To Clean Cylinder and Piston Head Plug Hole?
Has anyone come up with a decent way to clean the piston heads through the plug hole? I am planning on fabricating a small metal or plastic straw like tube to the end of a wet vac and spraying brake cleaner into the cylinder. Curious if anyone has had luck with this? My engine is old and I'm planning on a rebuild in August. Until then, due to cracked plug tube, just want to clean out some of the carbon and minor junk in #4 and #5 when swapping plugs.
Don't spray brake-cleaner where it doesn't belong.
Also I don't think a cracked plug-tube will cause gunk to build up inside your cylinder. It's plugged up by the plug, after all.
Thank you for your feedback and you're probably right. However, to explore a little deeper my question then is why would brake cleaner be a problem for the cylinder? I understand it's a solvent, but so is gasoline. Also, what is "bore-wash"?
Gasoline enters the cylinder in vapour form in very small quantities and burns off directly after injection, so tens of milliseconds after being injected. Spraying brake-cleaner inside your cylinder with the purpose of cleaning will easily be >100x more solvent than the amount of gasoline your engine usually injects for a single stroke.
With severe misfiring in a cold engine or a broken injector, you'd also be at risk of bore-washing your cylinder.
