Wheeler Dealers 996 Project
#91
Team Owner
#92
I'm still curious about how the over revs impact the decision especially with the 996's. There's no way to know how high the revs went. Are any over revs disqualifying?
#94
Dean of Rennlist, "I'm Listening"
Gentlemen -
Please cease the personal stuff.
Thank you.
Thank you.
#95
#96
Just a car guy
However, the implication of type 2 and greater over revs, is that this is usually as a result of a mechanical over rev. This can cause a number of problems: from stretched chains, to piston to valve contact.
I'm sure those with more experience, in this area, should be able provide more and better detail.
#97
I will not attempt to answer the question about disqualifying the engine for the Solution.
EDIT - And I guess if a bad rev report is disqualifying for the IMS solution, it's a car he shouldn't be buying anyway.
#98
Wheeler Dealer is a television program whose intent is to appeal to a broad audience, not just 996 fanatics. I have been watching the show for many years, even before it ever aired in North America. At first I was not a big fan of Ant. He is actually pretty good. What I do miss is that the earlier episodes got into a lot more detail of what was being done to the cars. In one episode, Mike uses a deck of cards to cover a tire to paint the rim. This was a very useful cheat!
Yes, a lot of steps were missed on air for the IMS Solution install.
So what? It was fun without the ridiculous drama of a lot of other auto shows.
#99
While you don't know technically how long the car was in an over-rev situation, you have plenty of data to know how long it _could_ have been. My car had 25 range 2 ignitions when I checked prior to purchase. At the rate of 3 ignitions per revolution @7k RPM, round down, and you get... 300ish ignitions per second. 25 goes into 300 12 times...if all 25 range 2 ignitions for my car happened in the same incident, the longest period it could have been running at that speed is about 1/12th of a second. Since I also knew that the last Range 2 ignition happened many operating hours ago, I felt that there was negligible exposure for this particular concern.
#100
well, 1/12 of a second may seem a short time, but in my experience recorded over-revs are typically that short - something else happens to slow things down immediately; clutch/wheels/ground. more telling is the time elapsed since the over-rev; did it just happen or has the motor been running happily for hundreds of hours since?
#101
The range-2 ignitions I've seen happen in real life are almost always due to money shifts at the track. For a car I don't know anything about, that's what I want to look for recent evidence of - some clown who doesn't know how to drive it hooning around and yanking it down into the wrong gear. If you can't get 0 range 2 ignitions, a small number that hasn't increased in a really long time trumps (er, is better than) a giant number that recently got even biggerer.
The engine isn't meant to spin beyond a given speed...but safety margins exist for every part in an assembly to allow for metallurgical flaws, finishing issues, production variance, etc. My hope was that the Range 2 ignitions happened so long ago that any failure introduced or weakness exacerbated would have long since presented itself. Thankfully, that's been the case thus far.
#102
Decent episode. Replaced IMS with LN Solution. Did a few other minor fixes and upgrades. Paid $16k then sold for I think $22,500. Reasonable money for a MY2000 C2 Cabriolet.
#103
I never watch TV. I didn't;t even know this was coming on, till someone shot me a text while they were installing my IMS Solution.
Watching that install made me cringe... granted, this isn't a technical show, but now we are going to have all sorts of people thinking you can get away without pre- qualification of the engine, locking the engine at TDC #1, not locking the cams, and more.
This reminded me of why I don't watch TV.
#104
It's a TV show, they can't show you every step they took...Lots of editing to make it all fit into their time slot.
#105
