Intermittent check engine
#31
Do you agree that the 245 would fit in the front, based on what I posted above?
And yes, I might consider an entire winter wheel / tire package. But seeing I just got this less than a week ago, that is at least 6 months out of my mind. Oh wait, did I say out of my mind? lol
#32
Just a car guy
Here are my numbers:
Seeing that I don't want to downsize the rear tires, I think my preference would be to get 245 in the front, if they would fit. Seeing that my current tires are 25.5" diameter / 9.3" wide, a 26.7" diameter / 9.6" wide tire should fit:
What do you guys think?
As well, I can get Ultra High Performance All-Season tires in that size at a reasonable cost, eliminating the need to swap tires / rims in the winter.
Thoughts?
(this is exhausting)
Thoughts?
The C4s and Turbo have a viscous clutch that applies torque to the front wheels whenever there is a difference in back-front wheel speed. The more the speed difference, the more the clutch applies, you will destroy the viscous clutch with your present set-up , let alone ill handling and dangerous..
#33
Just a car guy
#34
I should retract this [[[I measured with a ruler and it is right around 9". Since the existing tires are 9.3, I figured a 9.6 (for the 245) shouldn't be a problem. And the rims extend beyond the tires (outwards), if that says anything.]]]
I suppose the only real way is to have the tire removed and the thing measured?
When I got it, I drive a few miles and heard a high pitched noise coming from the front. It didn't seem like it was speed related. It went away when I turned right and it hasn't come back since. Is that what I could expect from the viscous thing?
Luckily these tires look almost brand new. Perhaps the owner just put them on with the larger wheels.
#35
Just a car guy
If you are not sure if you measured correctly, there should be stampings or cast-in dimensions on the inside of the wheels. You will want to be sure of this. Guessing and rushing into an uniformed purchase is not a good plan. Didn't you already question, WHO DOES THIS?
I can't answer the question about the noise. I am not knowledgeable enough on Porsche's system to offer an opinion. But it's not out of the question that the viscous diff was objecting to what it was being asked to do.
#36
Rim width is measured on the inside of the bead. You could easily assume you have a 9" wheel if you are not aware of this. See below:
On a positive note (maybe), I did see that the front struts were replaced with Bilstein B6 Performance units.
#37
#38
Not really any need to remove a tire. Porsche wheels have the “J” contour beadseat as shown here in the center sketch.
You can get reasonably close to the dimension inside the beadseat by measuring the overall width of the outside and subtracting 2 x 11mm= 0.866”.
#39
I used an inspection camera and all I could see on the inside of the wheels was "R46 A980". I couldn't see much else. I'll have a tire removed tomorrow as they are probably not porsche wheels.
#40
The brand or manufacturer of the wheels don’t matter, the bead seat area Dimensions are an industry standard that both wheel and tire manufacturers adhere to, so that tires interface properly with wheels.
#42
Just a car guy
Just remove a wheel from the car. Look inside the wheel - you do not need to remove the tire. There will be a lot of information in there. The rim width, wheel diameter and offset should all be there. Wheel manufacturers are required to put this information on all wheels.
The important stuff is in the first few seconds of the video:
Take a picture and post it here if you need to have it decoded.
#43
https://www.youtube.com/watch?v=W6_Bk3OCLII
#44
Just a car guy
Yes - 19 x 8 with 46 mm offset (and J is the bead profile as previously pointed out). I'll have to see if I can find a Tire & Rim Association Yearbook (it is the bible for wheel and tire engineers). The interwebz are pretty good at this stuff too.
Can you do the same at the rear? Also, please confirm you have a 295/35 tire. I saw a few inconsistencies between your numbers and what Charlie posted for the original 18" fitment.
Looks like 245 might be a good fit on an 8" wide wheel. I'll get back with a recommended aspect ratio when I know, for sure, the size of the rear tire.
#45
As I mentioned, I would like to go with the 245 / 40 / 19. It looks like it should fit fine .. if you could give me your 0.02.
Using the tool here: https://tiresize.com/calculator/ and what I saw on tirerack, the 245 works on a 8-9.5 wheel width.
I'll leave the rears as they are.
