996 Forum 1999-2005
Raceworks coilovers?
Old 05-02-2019, 10:02 AM
  #46
TheYoung911
TheYoung911's Avatar
Originally Posted by FrozenApples
First thing of note is that they only come with rear sway bar links. I guess it's not clearly stated on the site, but I had assumed it came with both front and rear. Turns out that's only with the C4.
Will definitely update with pics and impressions as I get them fitted.
Edit: they come with rear. Lot longer than stock due to the height of the connection on the shock body.
So they only offer front links on the C4 kit? Also sorry to hear that.
Old 05-02-2019, 10:27 AM
  #47
FrozenApples
FrozenApples's Avatar
Yep, looks like they just updated the site​​​​​ to clarify. Wish we would have known that before ordering. Also, the Novak is on sale for all models $980 now.
Old 05-02-2019, 11:37 PM
  #48
FrozenApples
Started with the rear cause it's easy. Already hit a snag. The top mounts don't line up with my bolt holes.
Old 05-02-2019, 11:50 PM
  #49
Apollo76
Apollo76's Avatar
Old 05-03-2019, 09:17 AM
  #50
FrozenApples
RaceWorks was quick to reply. They confirmed it's a mix up with 986 mounts. New mounts on the way.
Old 05-03-2019, 11:47 AM
  #51
Rdrcr
Rdrcr's Avatar
Okay. I'm glad they responded quickly with a fix.
Mike
Old 05-03-2019, 11:58 AM
  #52
FrozenApples
A few pics. Here's the rear comparison. This is at the max height adjustment. It's maybe 1.5in shorter than stock. But I assume the spring will compress less, so the minimum drop should be less.
Second pic shows the bottom cup threaded all the way off. There's a break in the threads I assume to show the minimum threaded distance (max height setting).
Everything feels pretty robust, but I don't have much experience with other coilovers for comparison - so take it with a grain of salt.
Old 05-03-2019, 03:32 PM
  #53
FrozenApples
Adjustment ***** per request
Old 05-03-2019, 06:53 PM
  #54
TheYoung911
Good to hear that Raceworks helped you out. I assume your project is left on hold for now?
Old 05-03-2019, 09:25 PM
  #55
FrozenApples
Gonna try and take a swing at the front this weekend. Already checked the bolt pattern is correct.
Old 05-04-2019, 01:15 PM
  #56
Rdrcr
Rdrcr's Avatar
My fingers are crossed and I look forward to learning about your progress.
I still haven't received any shipping/tracking information yet.
Mike
Old 05-04-2019, 02:19 PM
  #57
Dion Houng-Lee
Dion Houng-Lee's Avatar
I am told my set should be arriving stateside this week and then they will fit the eibach springs and ship it out.
Mike
Old 05-04-2019, 02:49 PM
  #58
Rdrcr
Rdrcr's Avatar
Good to know. That's my situation too. Hopefully they'll arrive sometime next week.
Mike
Old 05-04-2019, 06:24 PM
  #59
FrozenApples
Got the drivers front on. The top 3 nuts are bit small, so I reused the stock ones.
The drop at max height is only about 1/4in.
I had to remove my caliper as the brake line was too short to allow the original strut to swing out. I read others did not need to do this.
I removed the 10mm holding the brake sensor wire on the left and the 10mm holding the brake line on the right.
I removed the pinch bolt and then loosened the 4 bolts I show on the bottom. Didn't need to touch anything else to get the old one out. The new one is much shorter. I used a jack to hold the wheel carrier up while I tightened the pinch bolt on the new strut.
My only complaints so far are the small top nuts, no matching bracket for the electrical lines on the back of the strut, and the adjustment nut on the top of the strut looks like it wouldn't fit in if adjusted at max towards the inside of the car. It's already tight to the inside with a middle setting.
Should have the other one in tonight.
Old 05-04-2019, 08:14 PM
  #60
Rdrcr
Rdrcr's Avatar
Looking good. Thank you for the update, pics and info!
Mike
Quick Reply: Raceworks coilovers?
