996 Forum 1999-2005
Oil pressure PANIC
Old 03-10-2019, 07:03 PM
dak911
dak911's Avatar
Default Oil pressure PANIC
Driving about 7-8 minutes after startup, I notice htat the oil pressure gauge is at 0....PANIC... smack the dashboard....jumps to 4 whew...
Is this something that can be "fixed"?
Old 03-10-2019, 07:14 PM
DDzPorsche
DDzPorsche's Avatar
Most likely the oil pressor sender. Not expensive and you could DIY.
Old 03-10-2019, 07:44 PM
dak911
dak911's Avatar
I am thinking the needle sticks..??
Old 03-10-2019, 07:53 PM
DDzPorsche
DDzPorsche's Avatar
Unless the needle was at 0 for the 7-8 minutes it it not likely stuck. Do a search you will find this is a relatively common problem.
Old 03-10-2019, 08:19 PM
NYoutftr
NYoutftr's Avatar
Most likely sending unit.
I panicked the first time my gauge went to zero.
Replaced the sending unit, no further issues
Old 03-10-2019, 08:39 PM
dak911
dak911's Avatar
Point is I don't know if it did register when I first started it...didn't notice, it has been working fine otherwise.
I'll keep an "eye" on it
Old 03-10-2019, 08:55 PM
User 63031
User 63031's Avatar
I'd say if smacking the dashboard unit fixed his issue, his problem would exist in that general area, not at the sending unit which is in the back on a heavily vibrating engine.
Old 03-11-2019, 12:20 PM
Blue Chip
Blue Chip's Avatar
Agree with above. Smacking the dash suggests that it's an issue in the cluster and perhaps not the sender.
Old 03-11-2019, 12:31 PM
Mike Mullins
Mike Mullins's Avatar
Sending unit flakey, have had it, replaced it, U smacking dash was coincidental, with it coming back.
You can clean the Sending unit contacts, but replace it, 60-75.00 depending on outlet.
Look no further.
Old 03-11-2019, 12:34 PM
NuttyProfessor
NuttyProfessor's Avatar
AAAaaaAAAaaaaAAA... The Fonz lives!
Old 03-11-2019, 12:54 PM
User 63031
User 63031's Avatar
Look no further.
Hell of a coincidence then
It would help for OP to re-affirm the causality of his smack and the needle jumping back (was it instant etc), and if it is like he says I'd like to discourage the blatant dismissal of causal symptoms on the basis of 'coincicence'.
Just because many of you had another issue with your oil pressure sender, doesn't mean *all* oil pressure gauge issues are caused by that.
Old 03-11-2019, 01:31 PM
Mike Mullins
"Just because many of you had another issue with your oil pressure sender, doesn't mean *all* oil pressure gauge issues are caused by that."
your right, let him figure it out. Please respond back.
I smacked my Dash, nothing, I must have missed where to smack it exactly.
The Oil pressure gauge is part of Instrument bezel that has 3 high concentrated connections that don't tend to work loose, very secure. Do any other gauges or lights flicker?
OP said
Driving about 7-8 minutes after startup, I notice that the oil pressure gauge is at 0.
Huh, Did you notice the red warning screen? If it was O at startup it wouldn't have lasted 7-8 minutes without Oil pressure
Leave it alone and it will continue to happen more often.
Clean contacts, it will reduce events, but they won't go away.
Old 03-11-2019, 01:59 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
If the sending unit failed, you can hit the dash with a sledge hammer and gauge will not more. I would look for the problem in the connector at the gauge cluster first and go from there.
Old 03-11-2019, 02:36 PM
Mike Mullins
Your right if the Sending unit fails, No amount of pounding will bring it back,
But flashing between O - 5 Bar , It's intermittent, a sending unit is a analog electro-mechanical pressure device.
Again, OP needs to Troubleshoot it and tell us what he finds. This should prove interesting.
Please let us know how many parts you break taking the Instrument bezel off, a Hazard Switch? , a Microphone bezel, One of the connector bails either White Blue or Green? , Or marks it makes in setting it on top of dash.
Old 03-11-2019, 03:00 PM
User 63031
User 63031's Avatar
Haha, yes he should just replace the sender already because that's the easier job, doesn't matter to know what actually causes the problem first!
Like losing your keys in the dark alley but searching for them on the sidewalk because the light is better there
Quick Reply: Oil pressure PANIC
