also, whats the best way to hold shock piston to tightem shock nut? Originals had a Torx center
I'd suggest using a small wrench to hold shaft, and a crows foot or similar on the nut with torque wrench at 90 degrees (if crows foot is perpendicular to the shaft of the torque wrench, you don't have to do the math to calculate extra length).
