Locks, frunk & trunk release levers, rear defrost
Received 1,091 Likes
I would try a jump start with a running vehicle before doing anything else. You may have enough battery power that every thing looks normal, but the starting circuit requires many amps to kick in.
The battery is good and there has never been water infiltration. Anyway, I had it towed to the dealer. A few days later I got the call it was fixed. When I picked it up I told the service manager we'd check it together. So out on the lot he hits the fob button to unlock it and nothing. Embarrassed, he went and got the service tech.
Once again, the fuse under the seat was changed. The tech tells me my tape job screwed up the box. Here's what I did: There's two looms of wires that plug into the box. One of the connectors has a lock/release mechanism. The lever on the release is plastic and it crumbled when I touched it. Since there was no locking the connector now, I taped it. According to the tech, the tape job somehow interfered with the box's function.
Afraid of blowing the fuse, I don't use the fob now. I use the key in the door to lock/unlock, and I don't worry about the alarm since it's what seems to blow the fuse. I don't know what this fuse has to do with the rear defroster, but it works now too.
The fuse blew before my tape job, so the original cause of the problem was not addressed. I expect a new box under the seat is in my future. At least I have a spare key now.
Step 1: ditch your dealer and find a reputable Indy.
