Possibly buying first Porsche in 2 days
I was the first to reply to this ad:
https://waco.craigslist.org/cto/d/wa...817175656.html
Looking at it Wednesday morning. Been lurking on here and avidly reading about 996s for the past few months. Wasn't ready to jump on anything and then found this deal. Feel like I could fix a few things, drive it for a while, and turn it around without getting hurt. What I really want is a Coupe (backseat room for kids), but you can't be too picky when scraping CL for deals.
I'm curious if anyone knows how to validate the crate motor from Porsche. It would have been replaced in ~2015. He's looking into contacting the shop that did it in GA for some evidence. I'm curious what kind of IMS bearing a crate motor from that timeframe would have.
No PPI planned. I'm fairly mechanically inclined and have done just about everything short of rebuilding a motor. Watched a few PPI videos and will print out a few checklists to make sure I hit the critical items. Overall, just looking for any feedback or suggestions before I head down Wednesday morning to check it out.
For future reference (when the ad goes down):
for sale: 2000 Porsche Carrera Convertible
Good:
- Motor was swapped for a brand new motor around by previous owner around 65k miles. IMS bearing and common mechanical failures for iteration have been taken care of.
- Mechanically the car is in incredible shape. Engine sounds and runs like new (it is essentially!). All gears are tight and clutch is perfect. No check engine light and recently had the rear tires replaced and the car aligned.
- 6 Speed manual transmission for that real driving experience.
- Interior looks great for nearly 20 years of service. Driver seat has some minor upholstery tears but is still comfortable and form fitting. Rear seats are like new. Soft top has no tears or damage. Sound is pretty good for an older vehicle, and wheel only has one small wood trim piece that has come free.
- Clean title in hand, and car is priced to sell. Record of maintenance I've had done is included.
- Never been crashed or bumped, mostly garage kept, and no body damage to speak of. Car is clean and looks fantastic after a detail.
- Brand new battery and brake light switch per routine maintenance checkup.
The "rough around the edges":
- Biggest concern is the convertible top has a leaking hydraulic cylinder and as such the roof is currently stable in the "up" position. I have a quote in hand for repair for the leaking cylinder at ~$1100, and replacement of both cylinders at ~$1400. I'm happy to refer you to the mechanics where I was quoted, but wanted to allow buyers to use their trusted mechanic.
- Passenger side muffler tip was damaged and has fallen off. Any nearby muffler shop should be able to throw a new one on an pretty affordable price.
- Some switches on dash are out of service, but the key lock system works perfectly.
- Drivers side rear floor mat needs to be replaced.
Why I'm selling:
- I'm moving and don't have room for second vehicle, and I recently upgraded to a newer sport luxury car.
- I'm sure someone can love this car as much as I have and have just as much fun driving it.
Other info:
- The car is priced to sell. I'm not desperate or in a rush, but would like to see it go to a good home.
- The car values out for private sales at $12,500 on KBB, and I have come down 2k to accommodate the top and muffler repair.
- Must have cash in hand for a test drive.
Reach out to me with questions and I can provide any other information.
Good:
Why I'm selling:
Other info:
I would walk away from this one, too many odd things in the ad.
"Some switches on dash are out of service," - Which ones exactly?
"No check engine light" - Why state that? Probably because it was on recently, and he had if fixed, or disabled somehow.
Crate motor - need to know who this was purchased from and who put it in.
Like I said at the beginning, walk away from this, there's lot's better out there.
Engine serial number will tell you if it was a factory replacement.
It will start out: M96/01AT
AT means it was a factory replacement engine.
The IMS bearing from that time would have been the larger non-replaceable one.
It is suggested that you remove the seal from the bearing next time you're in there.
Switches out might not be a big deal.
My defroster is out and I just haven't gotten around to fixing it.
If PSM isn't working, or AC controls, or...? then it might be a big deal.
The price doesn't seem too bad though depending upon mileage and condition in person.
I'm a coupe guy too.
I would probably pass it up because of that reason.
I don't like the extra road noise and I hate driving with the top down.
I don't really like the looks of the hard top either.
Get the serial # on the motor. Underneath drivers side. Google it for location if u need. Then post it here, I'm sure someone can decipher it.
I'm sure one of top 5 questions buyers ask is if any check engine lights on. It gets annoying.
I have an OBDII reader I'll bring along, but it won't help if he cleared a code and the issue is intermittent.
He said a shop in GA put the crate motor in while the car was owned by his dad (3 years). He's owned it for the last 2 years. So earliest that put's the motor replacement around 2015. He's calling the shop today to see if he can get some records. I'll be calling as well to verify.
I'm definitely not afraid to walk away if something doesn't smell right. But at this price I think it's definitely worth the 2 hour drive to check it out.
Yes, without a doubt I wish it was a coupe (and that it was red), but I also am not convinced I will enjoy driving a 996 enough to justify the cost/maintenance/engine risk. I used to have a Miata and absolutely loved the handling experience, but everything was dirt cheap and easy DIY. Plus no back seats. I've got 3 kids now and would really like to include them in the fun. Coupe has more room for them too. So at the end of the day, if I love it and think it's worth it, then I'll likely be selling this one (hopefully break even) and move on to a coupe. Haven't yet found a coupe I felt I could break even on if I don't like it.
And agreed, that's not a big red flag for me. Very common question.
My 12yr old daughter can fit in the back seat, but that will change fairly soon.
My son probably could have fit until he was about 10 or 11.
He's 19 now and there's no way he could ride back there now, at least he would NOT be enjoying the car then.
I've had a couple of 12 year olds back there at one time, but they were cramped.
The front seats are for enjoying the ride, the back seats just barely beat walking.
The good part about the backseats being unusable once my daughter gets a little bigger?
I'll finally get around to installing my RSS bolt-in roll bar that's been waiting since last April.
If I am reading correct your price is $10.5K which is pretty good. Here is a similar car on ebay for 9K with a lot more miles.
https://www.ebay.com/itm/2001-Porsch...4:pf:0&vxp=mtr
If its an new engine at that price it seems like low risk. Also, If you need parts for top I would check with Norspecdismantling.com I got a whole convertible top assembly for my boxster with glass much cheaper than any other option.
https://www.ebay.com/sch/m.html?_odk...tible&_sacat=0
At that price it would be hard to go wrong, be sure to remove the oil filter housing & inspect the oil filter for anything other than oil in it. If the oil looks like brand new on the dipstick do as long a test drive as you can, then inspect oil filter.
Don't overestimate the room in the back of a 996 coupe!
Thanks for the link! I've been shopping around elsewhere and saw ~$700 for a new hydraulic lifter. Also found a questionable $30 rebuild kit, which goes against most of the forum recommendations. Will definitely start a fix up thread if I actually pick it up.
Great tip! I did not know you could drop the filter housing without changing the oil.
Shameful Thread Killer
I'm telling everyone right now, this car has had water inside. Prolly quite a bit of it. Be prepared for a lot of electrical tinkering for - ev - ar.
Hyd cylinders can be rebuilt. It takes time, and close attention to detail. Just depends on how the orig was made. Some will never seal right without the specific press used when it was mfg. But, will be worth giving it a try.
The other thing that troubles me is the comparative neglect shown. Things start to go bad, and don't get fixed. If the seller is admitting to several flaws, imagine the flaws in the car that aren't mentioned. Don't worry, you'll find them - eventually.
Go for it. You’re not risking too much at that price. I’d also started poking around on the Rennlist marketplace, Craigslist, and eBay for replacement seats up front. The driver’s seat especially looks to be in sad shape with some significant cracking. Upgraded interior is a nice touch, you’re going to love that bulkier shifter. And those Sport Classic wheels are a nice touch ....
This is the kind of ad I like... a roll of the dice!
I'd have no prob jumping on this because I like cabs. Fair warning, I did a lot of my own convertable work on my boxster but because I loved the car, it was worth it. e
I'd drive this with the top down and my two kiddos in the back with pride. Just pretnd you're in a 356 speedster climbing your favorite twisty roads!
YOLO!
YOLO!
Got the receipt from Buckhead Imports in GA. It was not a factory replacement motor. it was a used motor (38k miles). It was replaced at 85k miles. The receipt shows IMSR20888 bearing replacement for $185. I'm guessing that's just a factory bearing they used. But in the end it's only 5k miles (2 years) old so pretty low risk. Total bill was north of $16k - god these engines are scary.
Seller is getting a picture of the serial number. There's a lot of unknowns with a used motor in there.
YOLO!
YOLO!
You mean the convertable tops take a lot of maintenance to keep running? I really loved the Miata design, just flip the latch and drop it, but that's a bit too low end for a Porsche I suppose.
