996 Forum 1999-2005
Fair engine core price?
Old 02-11-2019, 12:32 PM
JohnCA58
JohnCA58's Avatar
Originally Posted by dporto
Seems like a good deal as the tranny's are considered "almost bulletproof"... he doesn't mention the price for/with the engine though...
I believe it mention if he didn't have to separate the two, he was willing to go 1K for both..... at the end, I could have read it wrong.
Old 02-11-2019, 12:39 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
That's one heck of a deal for only $1500. It's a plug-and-play engine. Instead of rebuilding I would pull the manifolds and have a look at the ports for carbon build up, put a scope down the spark plug holes to see what the bores look like, do a leakdown test and if all looks normal, pull the valve covers to see what the cam actuator pads look like (replace them if needed) and I would then put the engine away as a spare. Use it when needed.
Old 02-11-2019, 12:40 PM
dporto
dporto's Avatar
Received 1,154 Likes on 791 Posts
Hmmm, yeah - that makes no sense! Less for both??? I read it as $1500 for the tranny, or $1000 if you bought the motor too (i.e. he doesn't have to take them apart)... But no price for the motor - I think he just forgot to include the price...
Old 02-11-2019, 12:50 PM
sb3
sb3's Avatar
I tried to contact this guy a few weeks ago and I was emailed back a link to Ebay. Looked a bit fishy. Too bad, because the town listed in the ad is only 30 minutes from me.
Old 02-11-2019, 12:56 PM
TexSquirrel
TexSquirrel's Avatar
Received 2,389 Likes on 1,266 Posts
Great price on a 996 engine.
That's cheaper than most of the Boxster engines I've found.
I'd pay that much for a 3.4 or 3.6 anyday.
As long as it turns over, I'd be happy.
I'd start tearing it down and saving my money for some Nickies!
Old 02-11-2019, 05:25 PM
MadIrish
MadIrish's Avatar
There is a separate ad for the engine where he asks $5k for the motor and says he can do the tranny for 1.5k if sold with the engine...
Could not verify that it runs after the rollover, the ad says. Says he is "open to any inspections or tests".
https://sfbay.craigslist.org/sby/pts...816546143.html
Old 02-11-2019, 06:04 PM
mayday1
mayday1's Avatar
An engine can run without lubrication when rolled over. But I assume it'll stop when the fuel pump sucks in air.
Old 02-11-2019, 09:45 PM
sb3
sb3's Avatar
Thats my plan. Nickies, JE pistons, ARP bolts, IMS solution, etc. First, once I get this engine apart I'm going to send the crank and heads out to a P-Car machine shop near me. Just need to find the time for this and the home and motorcycle projects in between.
Old 02-12-2019, 12:40 AM
TexSquirrel
Old 02-12-2019, 09:50 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
If the crank journals look good I wouldn't touch them. You can easily do that by just looking at them.
Old 02-12-2019, 09:53 AM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Most cars since electronic fuel injection have roll over switches that get tripped when the car rolls over and disables the fuel pump. This switch needs to be manually reset in order for the pump to start working again. More than likely that's what has happened here.
Old 02-12-2019, 10:44 AM
dporto
dporto's Avatar
^^^ makes more sense...
Old 02-12-2019, 11:32 AM
808Bill
808Bill's Avatar
6K for a motor and trans is a smoking deal if it checks out!
Quick Reply: Fair engine core price?
