my cats are kicking the bucket
Throwing a CEL for low efficiency on bank 2. I reset it a couple of times and it comes back, my car uses zero oil between changes so not contamination etc
I think at 112k miles they are toast.
What are my options? Should I bother with changing the O2 sensors? I have a borescope so maybe I should snake it in and look at the condition of them inside?
I'm in California so have to pass smog in a few months, I don't want to pay $$$ for OEM. I will keep an eye out for used cat's on local ads with lower miles.
I also considered cutting the cans open and welding in some new universal cat elements, anyone done this? I have a 2000 996.1 all stock.
Most likely not the O2 sensors (which have their own codes). Your best bets are:
- A used unit (search for "porsche 996 downpipe" for 3.4
- 200-cell sport cat inserts from Carnewal (ship your cats there for the surgery)
- CA approved direct fit aftermarket cats
Captain Obvious
Super User
Super User
Try swapping the downstream O2 sensors from one site to the next. If the code follows the sensor you have your answer. If it doesn't, you'll have you answer too.
I've been having the same problem. My remedy?... lots of "cat food". hahaha Yep, I been feeding it two cans of seafoam, and the CEL went away. If this doesn't work in the long run, I may have to replace the catalytic converters, but I'm hoping to wake up my dead cat! Those darn cat converters are crazy expensive!
I'd probably start with the O2 sensors, they're cheap enough to be worth doing, whether you continue to use your current cats or replace them.
I'm a fan of sport cats. I've had 200 cell on both my 3.4 and my 3.6 and they're great, they seem to have a seat of the pants improvement in performance (full disclosure: I've never dynoed my car, so I have no idea whether there is any actual improvement). A thing you might need to worry about is CARB certified or original equipment in CA - I don't have the same issues in VT, so don't know anything other than what I've read about the Republik of Kalfornia emissions regs.
It will do zero damage to the ceramic or metallic element, its only an organic solvent. In a best case it washes away enough gunk on the cat to up its efficiency enough to clear the code. My wife has loads of MEK at her work so I could get it from her.
Also good idea for trying to swap the O2 sensors from the banks to see if the code follows, I can try that this weekend.
EDIT: looks like acetone might work better
It's possible the cat element inside has come loose, in which case you may be able to open it up and re-weld the element.
Once the cat is off the car, you can shake it and you will be able to see and feel if the element is loose.
Ahsai, Can you elaborate on your experience with Carnewal's 200? Can' t remember where you live but you don't have problems with emissions test or cel's? You ship them over to Belgium, if so do you remember costs (I haven't contacted gert about that)? Looks like a really inexpensive option if someone could live with the time it takes to rebuild
I replaced my cats with MagnaFlow units bought from Summit Racing. I bought the CARB certified units for about $1200 for both. About a year and 10K miles ago and still no error codes.
Actually one idea I had was to pull the cats off, scope them to make sure the ceramic core hadn't actually collapsed or somehow been mechanically destroyed then if all looked ok I would try washing them with MEK (methyl ethyl ketone). Its a really good solvent for washing away any nasty organic residue, I figure its worth a shot.
I see they have an aerosol spray for the throttle body. I wonder how well that works?
In the meantime, I bought a cheap set off RLister. Chris, if you're interested in cheap OEM replacements (I think they have 80Kish miles on them), I'd be willing to fix my original set and sell you the pair that I bought at what I paid. PM if you're interested, it will be your cheapest option by far and I believe you're close to me - I'm in South SF.
