Throw out bearing
Throw out bearing
Can someone confirm that I've put the throw out bearing in the right direction? I forgot to take a picture when I took it off and from all the searching I've done in my manuals I never see a picture of the orientation.
Also, the spring clip at the end of the throw out lever doesn't engage very tightly holding it on. I was surprised when I took it off it was so easy. The rounded top of the spring that goes through the slot in the lever doesn't seem to really snap into place very tightly. it holds it on their with applying light pressure to the backside of the lever (as if trying to pry it off). Maybe that's normal but I just wasn't sure. Thanks in advance.
I'll take it back apart. behind the lever is a spring clip and a rubber circle/boot that goes over the post. Again I can't find any kind of schematic to show how that spring and rubber boot are supposed to be position there. I didn't intentionally rearrange that when I took the lever off but maybe it did and I didn't notice. Now that i'm thinking about it, does the spring clip and that rubber boot supposed to be together? I believe on mine the rubber is sitting ahead of the spring clip on the post. Maybe that rubber boot is centered in the spring clip and that is mounted on the post? I didn't look at the design of the spring clip when because I didn't remove them after releasing the spring from the lever.
That post has a mushroom head for the spring to clamp on (albeit lightly). The rubber piece should be between the fork and the spring. Let me send some pics later in a couple of hrs.
It's possible the post is worn out so the spring can't fix the rubber.
Captain Obvious
Super User
Super User
You should be able to hear the CLICK of the post sliding over the spring. To be sue, just try slightly pull on it and if it stays in place then the spring is on the proper side of the post/ball.
Ahsai, how did you get the inside of your bell housing so clean? I'm envious. it's actually something I've been trying different things to clean this on the tranny side and the engine side without creating a big greasy mess on by floor. I've resorted to spraying a cleaner in and using a catch bucket to catch excess liquid dripping out as i wipe and brush the inside carefully.
The second or third picture shows the clip mounted to the lever (with a rubber insert int the clip. I'm assuming then once that is assembled, you slide the whole lever arm (rubber piece and clip already on the arm) onto the post. When I took the arm off, I slid the curved end of the spring off the arm as all of my manuals simply said "remove arm" or something to that effect. Anyway, i need to clip the rubber piece and the clip itself onto the arm before installing. I left the clip on the post and the rubber piece is loose from the clip. I should have just taken the clip and the rubber piece off of the post and it would have made more sense to visualize how it mounts on there.
What you described is perfectly correct and it also confirmed my suspicion based on your photo. Just make sure you put enough grease on the post head.
Captain Obvious
Super User
Super User
If you have Dollar Tree in your area, get the cleaner calls Awesome or maybe called Amazing. It has an As Seen On TV logo on it, yellow clear bottle. I know, I know, as cheesy as it sounds, this product cleans extremely well and is only $1.25 a bottle. It has a high concentration of ammonia so if you spraying it, wear a simple mask or else you lungs will be exfoliated.......like mine did.
