What a day, now to figure out what's happening with the car
#46
UPDATE: well this week, so far I've replaces all 6 coil packs, spark plugs and wired in a new plug/connector for the cylinder 1 coil pack. While at it, changed the fuel filter, oil change and replaced the radiator cap.
it fired right up and ran great.
then I get a couple miles away and stop, only to see the coolant leak wasnt the radiatoradiatas steam was coming from the engine bay. Looked around that area and sure enough some splatter. I went ahead and tightened the cap down as it seemed to have a few spins to go, hopefully that's all it was and not a leak somewhere else.
I guess next step would be bleeding the system making sure no air is caught and then a pressure test. [Anyone know if you can rent/borrow these from autozone?] [Or what the approximate cost from an indy to test it? I dont really want to drive it that far to the closest indy].
what then? Water pump, expansion reservoir, thermostat?
damn....was really hoping to be able to take the car on a road trip to SoCal, about 250 miles each way this weekend.
Edit: the other oddity... the climate controls didnt come on, buttons dont work, no temp or fan speed, etc showing on the display. I will double check the fuse when I get back home and have a light.
#49
I'd drive it around (close to home) and get it up to temp, stopping periodically to check for leaks.
#50
Clean off the coolant cap and the expansion tank so you can see if there are new accumulations of coolant. Check the part number on the coolant cap (should be -04) and examine the tank for leaks. Those are good places to start.
#52
Yup, just installed the new cap. Pretty sure it want tight enough. Also found a hose clamp that was a bit loose. Between tightening those both up, didnt notice any more leakage
#53
