996 Forum 1999-2005
Car won't start!
Old Feb 1, 2004 | 02:42 PM
Chicago996's Avatar
Chicago996
Angry Car won't start!
Granted, its been about 10 days since I last drove and it is parked in an unheated garage, it still sux that it won't start. I hear this tak-tak-tak noise coming from the starter and that's about it. The clock has reset itself back to 1:00 am and for some reason there is my electronic oil level indicator with a countdown starting from 59 minutes, 59 seconds. Does anyone know the reason for that? The battery needle is barely moving off of the '10' mark. Called Porsche roadside and am promised an ETA of 90 minutes or less to have someone come jumpstart it.
So, the question that begs itself is how do I prevent and/or deal with this going forward knowing that there are still plenty of cold days and I won't be driving the p-car in this weather. FWIW, I don't have access to an electric outlet (because of it being a public garage).
The other question is that my garage does have some device to jump start the cars but I'm hesitant to use it. Is there any difference between p-cars and "normal" cars that will preclude me from using this device in the future if I follow the manual to the letter?
Thanks amigos..
Old Feb 1, 2004 | 03:12 PM
996FLT6's Avatar
996FLT6
Well if not running for awhile maybe unhook one of the leads to the battery so it won't drain out(cheaper way to go). A portable battery charger(kinda heavy) can be in the car or at home so if it dies can be jumpstarted with that. I heard that there is a device that you can hook up to the battery which can disconnect it but don't know much about it. What kind of jumpstarter is in the garage? Regards. Mike
Old Feb 1, 2004 | 04:01 PM
Chicago996's Avatar
Chicago996
Thanks Mike. It looks like the garage has one of those portable battery chargers. Do you know if there is a "special" charger that is safe for 996? I'm just afraid of frying out something inadvertantly. The 90 minutes ETA just expired so I'm calling Roadside again to find out wtf is taking them so long..
Old Feb 1, 2004 | 04:36 PM
BayArea Jimmy's Avatar
BayArea Jimmy
The "portable battery chargers" so called, is actually a fancy name for a rechargable 12V battery system, perfectly safe for your application.
If the 996 is your weekend car, may be a deep-cycle type battery or Optima Battery is more appropriate for you, assuming the charging system is OK.
"electronic oil level indicator with a countdown starting from 59 minutes, 59 seconds" don't worry about it, hehee... it tries giving you time to get the engine warmup
Old Feb 1, 2004 | 07:52 PM
parkman's Avatar
parkman
you can always just buy a charger that trickles the battery. It plugs your car into the wall so that the battery constantly stays charged. It will trickle (i.e. it will only top off the battery) and not overcharge the battery.
Another alternative is you can buy this tequipment battery charger :
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2456173095
for 63 bucks.
The last option is to buy the jump pack (the battery start up pack referred to above by other people) which you can pick up at track auto, advanced auto, pep boys, etc... or walmart. i always keep one on hand because I have a few cars that I rarely drive and also use it on my boat which sits in the marina half the year round. It's really convenient because you never worry about having to have another car to jump start your car.
Old Feb 1, 2004 | 08:36 PM
mightytaco's Avatar
mightytaco
I just got one and am happy to say that it rocks--and you can use it on different cars, too (or so I understand).
Saves batteries!
Old Feb 1, 2004 | 08:50 PM
Chicago996's Avatar
Chicago996
Thanks all. I really like the suggestion of the portable battery chargers. Any recommendations on which one to get or what to look for? Is there a certain voltage or minimum amp rating to watch for? SOrry, I'm just so clueless in this regard. The trickle chargers won't work for me as I don't have an electric outlet near me anywhere.
The car started up fine and is running fine now after driving it for couple of hours.
Old Feb 1, 2004 | 09:29 PM
sal's Avatar
sal
Get the Porsche battery maintainer. just plug into the wall and into the lighter and it takes care of your problem. it will not overcharge the battery. most dealers have them in parts dept.
Old Feb 2, 2004 | 01:21 AM
chitownbob's Avatar
chitownbob
Performance parts sells a quick battery disconnect. Might be useful for you if you are parking the car in a public garage where you can't plug a battery maintainer into a power source. Remember that your car alarm will not work, but at least a theif can't drive off because you have the battery key.
Bobby
Old Feb 2, 2004 | 11:39 AM
rideau's Avatar
rideau
Hi there
I just went through the same problem here in Toronto. My storage facility doesn't have electrical outlets for a battery maintainer. I bought a portable rechargable unit (the most powerful I could find). It has a nice safety feature.....green light when connections are correct, red light if you've screwed up. Worked perfectly. Fortunately, the battery had enough juice for the trunk release to operate.
Cheers
Ian
Old Feb 2, 2004 | 12:58 PM
parkman's Avatar
parkman
oops... I forgot to tell you, if you let your battery die too often your battery can go bad. then again batteries all die over time, but this will definitely shorten the life of your battery. as such, I would also like to recommend chitown bob's idea of having the battery disconnect lever. I've seen them in levers, keys, switches, etc... the thing to remember is though, like someone said above, if you go this route, you will be turning off the alarm and also each time you turn on the car you will need to input your radio code... so make sure you have this handy.
Old Feb 2, 2004 | 01:03 PM
996FLT6's Avatar
996FLT6
My wife on 2 occasions had drained the battery on the Pepper mobile twice(left headlite on overnite) which man what a pain to call roadside assistance and play the waiting game. The portable jumper is the way to go esp you can take it wherever you'll go if something happens and man so much easier to jumpstart other people's cars(good samaritan) versus lining up the cars for the jumper cables. I'm picking one up from my mechanic today-I'lll et you know which brand it is : ). Regards. Mike
Old Feb 2, 2004 | 03:09 PM
parkman's Avatar
parkman
they usually cost around 30-70 bucks. a really nice one that has tire air pump and flash light etc... should cost you around 80-90 bucks at any auto store or at k-mart/walmart. Another thing to note is that you want to see the amps that it pumps out. Some larger cars or bigger batteries will require a larger amp output (one large shot at once) so that the car will start... especially if it's completely drained. As such, you should see what level of immediate output the charger offers...
Old Feb 2, 2004 | 03:24 PM
Chicago996's Avatar
Chicago996
The best solution for my circumstances, then, is to fork over ~$100 and get the best portable charger. I do intend on driving more often as soon as Spring is here (or at least the salt/snow/ice are gone).
rideau, I like the safety feature that you have on your charger. Would you mind sharing the brand/model name please?
996FLT6, I'm also curious to see what your mechanic recommends.
On a totally unrelated note, I saw a black (I think or could be some other dark shade) 996TT near Oak and Rush yesterday, pretty much caked with salt parked next to a meter. I almost cried!
Old Feb 2, 2004 | 04:19 PM
rideau's Avatar
rideau
Hi There
This won't do you much good.....our leading Canadian autosupply chain is Canadian Tire and my new unit is their branded version....will look in manual this evening for you to see if there is a manufacturer listed.
Can't wait until spring!
Cheers
