Our 968 and 944S2 supercharger kits are still available
I have had a couple 968 owners contact me and ask "I heard you discontinued the 968 supercharger kits... any chance you will make them again?"
The fact is, we never discontinued that kit! They are very much still available.
Stage 1 kit: this kit was designed for quick and easy installation. It represents the most boost (about 6 psi) that we could apply to a stock 968 using the stock injectors and the stock engine management. No changes necessary to either one. Its a good and fun kit for the street. https://928motorsports.com/parts/968...harger_kit.php
But then, a couple fellas took our Stage 1 kit to the race track and reported that they had belt-slip issues. That is how the Stage 2 kit was born... it is our "go nuts" kit for the race track. The stock injectors and the stock engine management are replaced with bigger injectors and the Electromotive Tec GT system so that the engine is fueled correctly. This kit also uses a two-sided belt, larger crank pulley, and extended belt-wrap so that all belt slip has been eliminated. The Stage 2 kit does not come with an intercooler, but several racers have added intercoolers to their installations. https://928motorsports.com/parts/968...percharger.php
No, I did find a company that had made the mounting brackets for a Rotrex supercharger in the past so Im sure they could do them again but gave up after that point. Really need to go down the road of forged pistons if you want to run enough boost to make it worth while
I bought maybe the last 928 motorsports stage 1 fitting kit and since the supercharger was Australian I sourced that directly from Raptor. Events have overtaken me as my 968 was writing off before I had a chance to fit it and the replacement is already boosted. If anyone is still looking for a kit I'm sure we can work something out
Just in case you don't want a stage 1 kit, I have a complete Stage 2 kit which is new. It includes the optional programming. This is a new setup which was never installed. Also included are extras such as different size pullies and more.
