Frunk light only comes on when glovebox is open?!
2002 Carerra. Hello, I've tried searching for another person with this issue, but can't seem to narrow it down. Bought 996, frunk light was working for the last month. Today, (or at least noticing it today) it does not come on. Strangely enough, it does come on when the glovebox is open! Before tearing my girl apart, it seems that it might be a microswitch issue, but not positive. Also, not sure if the problem is with the glovebox or the front latch. Any help or guidance would be appreciated.
I just checked the wiring diagram. Oddly enough the frunk, glove box, and engine compartment light are all controled by the alarm module on the same wire. Meaning if one is activated, they all are activated. So since the frunk light comes on when the glove box is open it is assumed the wiring is intact and good to the all 3 lights. I would also assume the micro switch to the glove box is good but the one for the frunk may not be. That is where i would start.
