Double Din install bad Metra kit?
I just need another opinion on this, I could be wrong, but don't know how I am. A couple of months ago I installed a double din headunit using a Metra 99-9605B mounting kit. The headunit doesn't sit flush with the stock dash so I went back in and was trying to figure out why. As you can see in the pictures below, I think the mounting kit is too tall to fit in the OEM cradle. It doesn't clear the bottom lip.
Has anyone had to "fix" this themselves?
The kit is sitting as "high" as it can in the cradle
Yet the fascia is too "long" to clear the OEM cradle lip.
The instructions that came with my install kit showed me where I had to trim the factory radio bezel, I ground it down with a sawzall and that was that. Super easy. Also buy the converter to turn your cigarette lighter into a usb port.
If I can dig up the install book I will post
I'm also using the metra kit. I can't figure out how to put the two black plastic U shaped pieces around the radio and still keep the cup holder. The metra instructions don't show the cupholder. Any suggestions?
thanks
Dave
thanks
Dave
The radio is sitting too high in the faceplate would be my theory, make sure you cut out the very top of the shaded area. Take a pic of what your cut out looks like now close up front view. I'll try and help.
Thanks but I guess I didn't explain the problem too well. The radio fits perfectly in the metra mount and the metra mount slides right into the dash chassis and sits properly. The problem is that I'm supposed to secure the radio to the metra mount and then secure the metra mount to the chassis then slide it all into the dash. It looks like the metra mount only works if you don't have the top mounted stock porsche cup holder.
I see what your saying, I had lost the u shaped plastic pieces by the time I got the radio mounted properly.
I ended up taking the whole plastic “cage” out of the car and I mounted the radio and the cage together on my work bench with some self tapping screws from the sides. Not optimal, but hasn’t moved at all.
Dave
I find it difficult to believe any qualified design was done on this. The two U shaped clamps that hold the head unit firmly(ish) in the Porsche factory horseshoe, foul the integral dashboard metal shelf that the horseshoe and head unit sit on, and also force the center A/C vent pipe up so it doesn't mate cleanly into the housing.
I will take photos and post tomorrow, but now consider the Metra mount to be rubbish! I haven't even started on the lack of sympathetic curves in the fascia bracket to at least try to blend with the OEM dash.
My only choice is to cut away the screw sections that connect the two U clamps and jury rig a lower profile connection so the new head unit doesn't pop out of the center console and visit the rear seat when I make a spirited takeoff at the lights.
I now consider the Metra a temporary solution and will likely carve something more functional and aesthetically pleasing out of mahogany or walnut.
I think this U-shape bracket is some kind of standard component put into the set without any consideration as to how to package it in the car.
The only way to assemble this properly is to screw directly the head unit in the cage.
Apart from that, I found the kit quality reasonably good, especially considering the cost.
