PSE Sound Clip
Cap'n Insane the Engorged
PSE is wonderful. Until you get it installed, you can burn this on a cd and play it in your car:
http://butifnot.tripod.com/racecar.html
rob, are the differences between the verions of the exhausts related to model years? i had heard that there was and older and newer version of the pse. what is the diff between the two standard exhausts?
I've had that for awhile so I'm guessing it's the 3.4L.
Scott in Houston posted a vid awhile back of different exhausts - TC's 3.6L PSE and DJ996's 3.4L PSE are both on there.
The PDE site has sound clips of standard and PSE (on current 3.6L engines). Click on link, then click on interactive specs, then click on engine and there are 2 sound clips at the bottom.
http://www.porschedriving.com/the_cars.asp#
I found the thread:
https://rennlist.com/forums/showthre...t&pagenumber=1
But I couldn't d/l the vid, maybe try e-mailing Scott to see if he still has it.
Now what would be REALLY brilliant would be if you could switch your PSE between the loud sound, and those two guys(?) on the sound clip!!
Does anyone know the weight difference between the stock and PSE units?
David
David
