Anyone have a flywheel lying around?
I need to take measurements of a stock 996 flywheel to make a custom one. If anyone has a flywheel lying around, let me know.
If someone can take some measurements of the holes and pins that would help me a lot.
Or if someone can send me a flywheel, I can take measurements myself, and return it after measuring it if you want it back. It doesn't matter how worn out it is or if the dual mass part is bad.
I'm also looking for a measurement of the flywheel clutch surface to the transmission mounting surface. If anyone is changing their clutch or has the engine out could they please measure this for me?
Thanks in advance,
Andrew
Thanks in advance,
Andrew
