996 Forum 1999-2005
Leaking coolent
Old Oct 16, 2018 | 10:08 PM
wyovino's Avatar
wyovino
Originally Posted by OverTake
Bill, thanks for sharing that. That's a big relief to know that the coolant leaking from the tank could be causing the misfire. An obscene amount dripped out in that area, so hopefully that's the cause.
If you're getting a misfire code, pull the coil(s) and check for moisture. Running with a misfire condition can damage the engine.
