Front Suspension/Steering Noise when turning right at speed
Hi,
Looking for any advice on what this noise could be. Been checking the forums and nothing seems to cover this one.
For reference the following parts have already been replaced with no effect:
LCAs, Top Mounts, steering rack (with innner tie rods). Springs and dampers are new (Öhlins R&T)
any ideas?? Noise does not occur driving straight, under braking or at parking speeds.
Thanks!
H
Thanks!
H
Here's what my strange steering noise turned out to be after replacing about all the same parts that you did with no improvement: https://rennlist.com/forums/996-foru...-solution.html
If there was enough "grip" under the tires when parked you could get it to make the noise when stationary by turning the wheel back and forth. I used the car mostly for track use and it was very noticeable under load when cornering on the track.
