996 02 ENGINE REPLACEMENT/REBULIT
MY 996 02 CABRIOLET 4 HAS A BLOWN ? ENGINE PROBABLY A WATER PUMP FAILURE ?
58K ON A PRISTINE,WELL MAINTAINED CAR. MY INDYTRIED TO CRANK IT AND WATER SPWED
FROM BOTH EXHAUST. PROBABLY CRAKED HEAD OR BLOCK ? GOING TO DRAIN COOLANT AND DO
A COMPRESSION TEST. INDY SAYS ENGINE "LOCKED" FROM WATER IN CYLINDERS.
I HAVE CONTACTED CHARLES AT LN ENGINEERING AND CAN SEND MY ENGINE TO THEM FOR A REBUILD
ABOUT 11.5K; (4 WEEKS LEAD TIME) IF MY ENGINE IS ACCEPTABLE TO THEM; OR BUY A REBUILT FOM THEM 15K AND 2K CORE EXCHANE
APROX 4 MO. LEAD TIME (I THINK THATS EXCESSIVE)
ANYONE HAVE EXPERINCE W LN ENGINEERING FOR AN ENGINE REBUILD OR SWAP; AND IF CO WHAT WAS IT?
They are one of the best options out there. You Indy never should have started that engine!
There are a couple of engines (good) for sale in the classified section here on RL.
Also, you can get a short block from Porsche for $7-8K
Oops, thanks for the correction...
Short $7k'ish (need to have your heads reworked $2K'ish) and long $15K … http://www.autoatlanta.com/results.php?partnumber2=Porsche%20996%20Short%20Block&narrowcar=911%2019 98-05
Coopduc just did this and I would have but Porsche of Hawaii wanted $9K and a $4K core charge.
I found a 50K mile motor that turned out to be a factory replacement for $6K. Next year the old motor will be rebuilt by the best!
I would get a rebuilt long block and swap it out. $11.5K is not a bad deal. I am sure Porsche wants a bit more than that for their long block.
I just did this for a friend and he bought a long block from an engine rebuilder in FL for $9k.
$11.5K from LN Engineering sounds like a great deal to me, especially if you can have them increase displacement for close to that price.
I've always rebuilt my own engines, and already have all the tools necessary to assemble an M96, but I'd at least consider having LN Engineering do it for that price.
A 4 month lead time for a rebuild with Nickies is a normal lead time for a proper rebuild where you get your original engine back and not some bait and swtich. The block process takes 6-8 weeks, plus time in transit, for sleeving and plating. Most budget rebuilds slap a coat of paint on the block and they add a bottle of motor honey and call it good, so buyer beware. I'd rather see someone put in a good used engine than a budget rebuild.
We've been sleeving blocks with our Nickies for well over a decade, with well over 1000 done in the last decade.
