996 Forum 1999-2005
Roll Bar Bolt Sizes
Old Jan 12, 2004 | 01:49 PM
RayGT3's Avatar
RayGT3
Question Roll Bar Bolt Sizes
I picked up a Tequipment roll bar but didn't come with the mounting hardware. Anyone know what size bolts are used to mount the bar? Also if I need anything aside from the standard nut/bolt stuff. I'd like to order the hardware before the bar arrives so I might install it as soon as it arrives. Tnx
Old Jan 13, 2004 | 02:12 AM
C4FDR's Avatar
C4FDR
You should be able to use the seat belt existing bolts, if not they are 7/16 diameter 20N tread. I would buy grade 5 or 8 in 2" to 2 1/4" length. These are avialable at your local Ace hardware. If you are installing harness' you may will want to use Brey-Krause products, R-9001 Tunnel Side Seat Belt Mount Kit and R-9003 Outside Seat Belt Mount Kit. These come with replacement bolts, however adding the roll bar may still require londer bolts.
