996 Forum 1999-2005
2002 Engine compartment emergency release cable
Old 07-18-2018 | 08:57 PM
hfuglaar's Avatar
hfuglaar
8th Gear
Default 2002 Engine compartment emergency release cable
I removed the drivers side rear light assembly to run a cable for a rear view camera. I found an emergency release cable for the engine compartment coiled up in the light compartment. I can find nothing in the owners manual about the cable. If I have to open the engine compartment to remove the bolt to take out the rear light assembly, then what good is the cable? Where should it be?
Old 07-18-2018 | 09:08 PM
fpb111's Avatar
fpb111
Right where you found it. A rubber kitchen spatula carefully wedged a little way between the light assembly and fender will allow you to fish it out with a thin wire hook.
Old 07-19-2018 | 02:30 AM
808Bill's Avatar
808Bill
Just duct tape it in place so you can easily access it when needed.
Old 07-19-2018 | 09:37 AM
jhbrennan's Avatar
jhbrennan
That's the issue - where is easy access?
Old 07-19-2018 | 01:33 PM
808Bill's Avatar
808Bill
Right there between the light and the bumper cover...
Quick Reply: 2002 Engine compartment emergency release cable
