Front tire question
Front tire question
I'm curious if anyone has run into this - it's a new one for me. I just had to buy my third set of tires (and for you new guys, budget accordingly), but on this occasion I had to change all four even though I did all four about 16k miles ago. On my last two sets, by the time the rears were bald the fronts still had plenty of tread. The only functional change to the car was swapping the old Turbo Twists for a set of OZ Alleggerita's (with fresh tires all the way around). The wear was pretty even across all tires, but in this case I would have said the fronts were even more worn than the rears. Any ideas why this might be the case?
Rick
Rick
I get an alignment every time I buy new tires. It has cut down on wear considerably, but the rears deff wear quicker due to the weight and my heavy foot.
I use firestone, they offer unlimited lifetime alignment (every 6,000 miles or 6 months) as long as you own vehicle. They use latest/greatest hunter machine which pulls from Porsche specs or you can have set what variables you want. I think I paid $249 bucks for that service.
Rick
Rick
Hmmm...I've never gotten an alignment done, but the drive has always been smooth so I never thought of it as a problem. Something to consider for sure. All of my recent sets have been Michelin's (PSS) so just weird that I would wear the fronts so quickly.
is the tire wear even or more so on one side of tire?
No, it was pretty even except that in this case the fronts appeared marginally more worn than the rears. At any rate, I’m going to be watching this new set like a hawk.
I run OZs allegeritas on my autocross setup. I likewise can run a set of fronts for two seasons but need a pair of rears each season. I will flip the fronts on the rim to get a fresh outside, since the car never wears the inside edge out.
I would highly suspect your front toe is out of whack.
Your smooth ride brought to you by Michelin & properly balanced wheels/tires. Alignment has zero effect there.
Well, that ended up as a humiliating learning experience. I got a 4 wheel alignment at the local Porsche dealership and it turned out that both fronts were out of spec with the passenger side tire significantly so. We probably won't know if this was the primary culprit for a few months or so, but the tech agreed that it would likely be a substantial contributing factor. Thanks for the feedback!
R
R
R
R
