L&N Engineering IMS adapter spin on oil filter types
I have a 2002 Carrerra that had the L&N IMS fix installed. I am about to do the first oil change. What spin on filters do you guys usr?
Napa Gold 1042 (Preferred)
Mobil1 M1107
K&N Gold HP-1007
Hand tighten, plus 3/4 to 1 turn
I had trouble finding the Napa Gold filters locally so I used the Mobile 1 and K&N Gold for a few oil changes. I eventually ordered a case of Napa Gold filters online.
Mobil1 M1107
K&N Gold HP-1007
http://www.oilfilter-crossreference....vert/NAPA/1042
Mobil 1 M1107, K&N Gold HP-1007 filter or NAPA Gold 1042
Mann ML 1013 Wix 51042
If you have IMS solution your filter is a cross with a Toyota Tacoma, if you have stand alone spin on adapter your filter is Wix 51042 or cross. I can look up the wix part when I get home.
For the regular spin on oil filter adapter, the only filters I would personally use are:
Mann (in an emergency only)
Wix 51042
Napa Gold 1042
Napa Platinum 1042 (equivalent to Mobil 1 / K&N but better) - reduced flow but better filtration, higher burst strength
For track, only use the billet washable spin on filter adapter.
