996 Forum 1999-2005
LN IMS retrofit question -- IMS stud
Old 04-23-2018 | 11:21 AM
Tyler H's Avatar
Tyler H
Default LN IMS retrofit question -- IMS stud
I'm ready to pull the IMS from my 2002 Carrera and the center stud diameter and thread pitch is smaller than the ID of the threaded rod on both the LN Pro Kit and Faultless kit.
Anyone else run into this and if so, how did you proceed?
Old 04-23-2018 | 12:32 PM
ChicagoSpeed996's Avatar
ChicagoSpeed996
Unfortunately or fortunately I did not run into that issue when I did the IMS on my 2002 996. Any photos of what is happening? Navarro or Raby should be able to help quickly.
Old 04-23-2018 | 12:49 PM
Tyler H's Avatar
Tyler H
I'm suffering from feelings of IMS stud inadequacies. Both of the hex stock pieces included have ID's too big for my IMS stud. LN replied quickly to my online inquiry and I'll follow up with them via phone.
What I have won't work -- I'm curious as to why, however to keep my job moving forward I'm going to head the local machine shop and get another piece of bar stock tapped to match my stud and the LN puller.
I'll post up what I get figured out.
Old 04-23-2018 | 05:21 PM
Tyler H's Avatar
Tyler H
Update -- confirmed that I'm missing a part from my borrowed IMS Pro Tools kit.
It's not obvious from the Installation manual that there is another piece between the puller rod and the IMS stud. The hex stock for the single row extraction is machined to match the M8x1.0 of the Porsche IMS stud and adapt the puller rod to larger diameter of the LN IMS stud. In the manual illustrations, the puller and adapter are already assembled. Makes sense once you see it.
I'll have to wait a few days to get the appropriate part.
Kudos to LN for being very fast to answer both electronic inquiries and a phone call. Great customer service.
BTW...stock IMS bearing at 121k miles looks perfect.
--Tyler
Quick Reply: LN IMS retrofit question -- IMS stud
