Buying an '02 C4S, PPI discovered oil leak/seepage
Hi guys/gals! I'm in process of buying an 02 C4S (~59k miles) and PPI, done at a Porsche dealership, discovered "front/rear main" oil leakage/seepage. They mentioned that it is minor and should keep an eye on it. The car already has IMS retrofit done (LN) so I was surprised to see this. The service adviser said that they have seen cars that are stored during the winter seep some oil during spring start ups. The picture below shows rear leak circled in Yellow, but I don't have a picture of the front.
Last oil change was done about 1k miles ago (last Spring), oil separator was also replaced due to an oil leak last summer.
What do you guys think - pass or proceed? I think the price is fair ($31k) given the condition of the car but do worry about this oil thing...
Everything else was relatively minor. It has been tracked before. Silver W black interior. IIRC, there were lvl 1 and 3 over revs... I will double check this.
Was just concerned that I would have to dump a couple of grand right as I buy it....
Range one - hit limiter (not a big deal)
Range two - mechanical over rev (miss shift) if over 120 hours ago usually in the clear <120 hours ago in danger.
Thanks. I just circled the red thing thinking perhaps that's where the front main leak is? Reading around, RMS appears to be ~1,200 fix and should be done when it's time to do the clutch. Clutch was previously replaced at 30k.... Just jolt sure about the front main seal.
+996 on maintenance records, although part of me questions why the owner has left these issues (RMS not so much).
Just checked, range 1 is 1,824 hrs. Range 2 is 271 hrs .
IMS was fixed and it has decent service history - documents from the last owner are available and carfax had some details as well.
Just don't drive yourself crazy "digging". Expect to pay a few bucks making things right when you find yours. This one seems to check a lot of good boxes. I went forward with mine knowing a heck of a lot less.
Car does sound like it's decent
Evidence of a minor oil leak would not stop me from buying a 996, especially when you consider the car is 16 years old. Once you acquire your 996 and start reading these forums that minor oil leak will be long forgotten, for you will discover so many more wonderful things to worry about. In addition to the purchase price, please have at least $5,000 in cash ready to put into your purchase. No one ever thinks they will need that much, but I consider that the minimum reserve fund for these toys.
That engine was leaking oil for a while. You are seeing seepage after someone cleaned the bottom of the engine. My guess from the picture is the oil pump from above, where the case is joined, or front seal in the red circle.
And someone used a regular hose clamp on the thermostat hose and really clamped down on it. I would be concerned about who was working on the car.
I wouldn't pay $31k. Buying a roller for $5,000 with a fully rebuilt $25k engine is a much better deal.
I am kinda leaning towards passing on this as @ 31k + potential for more down the road and it is touching a 997 territory. Would prefer not to deal with headaches right off the bat...
